Question about Thermador PRDS484GGUS Gas Kitchen Range
How do I check codes on thermador model prs484ggus
Thermador oven p304cs error code 43. This has happened several times before and would like to try and fix it myself. Heard it could be the sail switch is stuck/ dirty. How to access it
If you go here..
it's your model...
https://www.repairclinic.com/Shop-For-Parts/-x703330346373/P304cs-Parts
they have a trouble problem selection on the page lower left.
check it out also live chat and a 800#
Hope this helps you out.
Best to you.
Jan 11, 2018 | Thermador Ovens
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
Looking discontinued thermador parts
Refer your problem to an appliance parts distributor
Jun 08, 2013 | Ovens
Thermador c272u double oven error code f33
over temperature. Check the oven sensor, if ok, replace the relay board for that oven (upper or lower)
Sep 16, 2012 | Thermador Ovens
Electric coils for old Thermador cooktop Model #TMH45
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Jul 20, 2008 | Cooktops
F64 code on lower oven of thermador model cm302
Go to:
http://www.assuredparts.com/ThermadorRangeFaultCodes.html
F64 Lower oven cooling fan air switch not detected Replace air switch,replace cooling fan,check connections, check P6 on PCB control display.
f64 fault code is an issue with the lower oven cooling fan motor and, or (air) sail switch
Apr 12, 2008 | Thermador Kitchen Ranges
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Thermador PRDS484GGUS Gas Kitchen Range Logo
21 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
