Question about Xerox Phaser 8500/DN Printer
When I try to print to the Xerox 8550DP, I continually get a message that says "cleaning sheet needed" and I also always get the message "please load letter sized paper" (I haven't ever had to use that size before)
  • 3 Answers
This normaly means that the paper guides are set incorrectly, and the machines sensors are confused
Posted on Jan 21, 2010
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP printing duplex
are you not able to get even the print menu?
Jul 22, 2008 | Xerox Phaser 8550DP Printer
Displaying cleaning sheet required but there is paper in the machine and it wont print.
Try loading a sheet into the MFP.
If you have more than one tray look at your tray default settings, it should tell you in there which tray is set for your cleaning sheet.
Hope this helps.
Jan 19, 2011 | Xerox Phaser 8500/DN Printer
CLEANING SHEET REQUIRED FAULT
go to options and find cleaning sheet im thinking the jets are full of gunk... it is an option (cleaning sheet) i just dont have the printer near me but it is ill try to go out there and get you specifics but if not its under print quality options...xerox.com has some things u can try also
Dec 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
8550DP
That usually is a sensor failing. You can try to locate it (in the area where the tray goes) and see if it is loose.
Good luck.
Dec 13, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8200
There are special cleaning sheets that you need to get for this printer. Ask the company you get your ink from, they should be able to get you some.
Sep 23, 2008 | Xerox Phaser 8500N Printer
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Garbled text
Did you just install it ? Sounds like a driver issue.
The only other thing I have seen cause that is software corruption.You can do a NVRAM reset from the screen.
But I would try restarting the machine first. Then go to the Xerox.com site and download a new driver before resetting the NVRAM memory.
It sounds like either the program you are trying to print from of the driver is the issue.
I bet you are printing out code.
Jan 29, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser  8500/DN Printer Logo
217 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
