Question about Acer TravelMate 2702WLMi Notebook
How do I remove the back lcd cover on my acer aspire 3610 laptop
  • Acer Master
  • 5,660 Answers
Come in from the front.
The Top Cover has the LCD screen attached to it, and the hinges are attached to it. When you have the laptop closed, you are viewing the Top Cover.
AC adapter unplugged (Charger), battery removed.
Around the LCD screen is a Screen Bezel. This bezel is removed first. Look carefully around the bezel. Upon close inspection you'll see a series of rubber rounded tiny pads. These are Screw Covers. Take a small flat tip Jewelers screwdriver, and remove them, or pry them up to one side, so that you can get to the screw head.
The statement -> Pry, sounds bad. In essence these screw covers, are a half moon shape (Almost) of some rubbery material, and have a glue that holds them on. This glue 'resembles' a type of rubber cement. If you carefully ease the flat tip towards the edge of the half moon shape, where it contacts the flat bezel, push in, and pry up, you'll see they come off relatively easy.
Most of the time if you store the screw covers upside down, glue surface up, you can reuse them with no additional glue needed.
The only problem you'll have with them, is they stick to the screwdriver tip, and your fingertips! Hard to put them somewhere!
Be sure to remove all of them. Generally there are 6. Two per side.
(Top, Bottom, Left Side, Right Side)
Now remove the Philips head screws underneath them. (Have this shape +) (No.1 Philips screwdriver)
Now you have to pop the bezel up, and off. I would use two Jewelers screwdrivers for this. A small kit of Jewelers screwdrivers, can be purchased from a number of places, if you don't have any. An inexpensive set should do just fine, ($5?)
The bezel has a parting line, (Crevice/Gap), where it meets the Top Cover. Sometimes it's a little tough to see. Start with a small flat tip Jewelers screwdriver, and see if you can ease it partially in this parting line. It's a little tough to get the first one started. If it seems as though it won't slide in a little, (Depth of 1/8th inch, or half the width of a No.2 pencil), then move over, try again.
DON'T come in from the LCD screen side. You'll damage the LCD screen, AND the bezel. (Even if you're replacing the LCD screen, you'll break the bezel. Has to be taken off from the outside edge)
Part way in, on the outside edge of the bezel, are locking tabs. These are made of plastic, and formed when the bezel was made. They are part of the bezel. They are spaced around the inside edge of the bezel. They are spaced, Locking tab, space. Locking tab, space. Locking tab, space.
This is why I suggested to move over with the screwdriver. You may be trying to put the screwdriver in, where a locking tab is.
Once you get a start, and have the flat tip Jewelers screwdriver in the parting line, take a second flat tip Jewelers screwdriver, and try to ease it in the gap you've made. Put it towards the end of the gap, where it narrows down. If you cannot, ease the end of the screwdriver you have in now, down. This will pry up on the bezel.
You will see the bezel bend. It fairly thin plastic at this edge, but this is TOUGH plastic. Don't go crazy, but it will bend pretty far, before it would break. Use a fair amount of pressure, but use finesse.
See if the bezel will pop up a bit. You can also move down a bit with the other flat tip Jewelers screwdriver, and try to make another pry point. Working two screwdrivers in this fashion, puts less strain on that plastic bezel.
When you get the bezel up far enough, you'll hear a loud pop, or snap sound. You'll think you broke the plastic bezel. Nope! Just one of those lock tabs letting go of the Top Cover. Keep working around the edge. Watch the top edge. If you have a built in webcam there are small wires close to the webcam. Look in while you're popping the bezel cover up. Use a flashlight if necessary.
Once you have the bezel off, you're home free!
You can now see the screws that hold the LCD screen to the Top Cover. You can see how the hinges are attached. After you're done, the bezel just snaps back into place, then the screws are put in, and the screw covers.
Posted on Apr 24, 2009
Acer aspire 3610 screen flickering
It sounds like your video cable or your Lcd Inverter cables might be loose. You will need to take the lcd apart to get to them. The video cable is on the back of the LCD screen at the top. Remove it, then push it back in and use a piece of tape over where it connects to hold it in place. Also remove the other end of the video cable from it's connection and plug it back in. The lcd inverter is at the bottom under the lcd screen. It has two cables going into it. Remove both cables and then plug them back in. Put everything back together and hopefully your problem of flickering will be solved.
Mar 30, 2012 | Acer Aspire 3610 Notebook
Where can i get a replacement back cover 15.4" for my acer aspire 3610
Take a look here at eBay for spare plastics for the Aspire 3610>>>>>>>
http://shop.ebay.co.uk/i.html?_nkw=acer+aspire+3610+plastics&_sacat=0&_trksid=p3286.m270.l1313&_odkw=acer+aspire+3610&_osacat=0
Regards.
Nov 12, 2009 | Acer Aspire 3610 Notebook
How can i find out part numbers for acer aspire 3000/3610. I have a 3000 (broken screen) and a 3610 (dead) , can i swop the screen from my 3610 into my 3000?
The Acer 3000 series and 3610 series has different set of Parts, Hence Swapping the LCD screen may damage your other 3610 LCD also. Please try to get a replacement for Aspire 3000 LCD.
Thank you for using Fixya.
Oct 08, 2009 | Acer Aspire 3000 Notebook
Were can i get a new lcd rear cover for my acer aspire 3610 as mine is broken at the left hinge
You will probably have to get one from a bone yard. Have you tried EBay?
Mar 17, 2009 | Acer Aspire 3610 Notebook
Cracked laptop screen casing
I didn't find any clear information on other model covers and if they fit, but I did find a cover listed at a decent price.
http://cgi.ebay.com/New-Acer-Aspire-3610-15-LCD-Back-Cover-Hinges_W0QQitemZ200302544446QQcmdZViewItemQQptZLH_DefaultDomain_0
If found a link indicating the 3000, 3690 nd 3610 use the same LCD but that doesn't assure the cover is the same.
Feb 11, 2009 | Acer Aspire 3610 Notebook
Acer 3680
for the guest, it's lcd problem, what you can do is replace lcd, it will solve your problem with line.
for annmarie1122, try to re-seat the lcd cable (that connect lcd to motherboard), it's under middle cover (where power button is reside),
try also to use external monitor. is the display same with lcd ?
if it is same, it's mean your motherboard is bad. if not, it's mean something wrong with your lcd. it could be lcd cable or lcd itself.
May 28, 2008 | Acer Aspire 3610 Notebook
Acer aspire 3610 drivers
go to this link below and download the drivers need for your aspire notebook 3610.
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Good Luck, Kindly POST back with your results.
Jan 04, 2008 | Computers & Internet
Acer TravelMate 2702WLMi Notebook Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
