Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Insignia tv-30 inch ---model is-tvhd30 has burned capacitor-c359--need to know the value in mfd's.
  • leonspurlin May 02, 2009
    this part has a specific assigned value-it is located off the collector of horiz. output transistor.
    Sergeant:
  • 280 Answers
If it is in the power supply better check the rest of them. most should all be the same value so you may be able to get the value for the burnt one from that. good luck
Posted on May 01, 2009
  • coyotedave May 02, 2009
    Rated as inappropriate? You should have been more specific in the location! I was trying to help. never-mind.
I need to know what size run capacitor for compressor I need on a Weather King model 10AJB24A01?
You can see a pic at the web address provided. The number is located on the old capacitor and frequently a replacement will not have an exact fit that requires you to modify the space it rests in. The updated part number is
43-25135-16 it is a 3/30 Mfd capacitor. 30 3 Mfd 370V Oval Capacitor 43 25135 16
Sep 16, 2015 | Weather King Heating & Cooling
Need to know capacitor size for a upla036jaz compressor, unable to read
need to know model and serial # of unit to look up values in mfd.
May 02, 2014 | Ruud Heating & Cooling
Behringer xenyx 1222fx mixer capasitor
check the capacitor and its value and type. i havent see the equipment but knows about capacitors etc
it usually comes in values like 0.01 2.0022 and so on and higher value like 1 mfd to couple of thousand mfd.you shouls use the same value and the voltage for the replacement one has to be same or more in voltage since higher voltage is no harm but lower voltage will explode or burn in electrical appliances it is used as filters to block spark in the carbon or starting capacitor thich helps to run the motor if it is built to run with a starting capacitor like the one used in water pumps or electrical ceiling fans.
Aug 29, 2012 | Cars & Trucks
I NEED TO KNOW IF A 12000 BTU A/C CAPACITOR IS WORKING
Turn power off.
Pull the leads off the capacitor.
Read off the capacitor the microfarad rating. (example 5 mfd or 5/30 mfd)
If the capacitor is oval it will have two sets of lead connections.
If the capacitor is round it could have three sets of lead connections.
On the oval capacitor, with a multimeter set on mfd, place one meter lead on one set of lead connections on the capacitor and the other lead on the other set of lead connections on the capacitor. Make sure you have a good connection. Read the mfd reading on the meter. It should be within 5-6% of the stated mfd of the capacitor.
On the capacitor with three sets of leads you will need to look at the top of the capacitor by the lead connections and find which lead is "c", which is "HERM", and which is "fan". Place your multimeter lead on "c"(common) and "herm" lead and take the reading, then take your leads and place on "C" and "fan" and take the reading. Compare these readings with the rated mfd stated on the side of the capacitor.
Sep 02, 2011 | Heating & Cooling
Wont turn on was turning on and off
What is the complete model number? I assume this is a 32inch lcd. If it is then you need to check for puffed capacitors on the power supply pcb. If there are any you need to replace them with equal or slightly greater values. The values are printed on the capacitors in mfd and voltage.
To do this you need to lay the tv on a cushioned surface face down. The surface must be large enough to support the whole tv. This is to prevent damage to the panel.
Remove all screws securing back of tv, remove the back and check the power supply for puffed caps. The power supply pcb is the one with the power cord attached. If there are any they need to be replaced with a soldering iron. Let me know how this goes. Thank you
Apr 03, 2011 | Vizio L32 32 in. LCD HDTV
Power will not stay on , on my magnavox tv model 32mf337b/27 unplugged like user manual suggested but didnt work even after 30 hrs saw on magnavox.com a few people have had same proble with this model mine...
Magnavox has issues with puffed caps on the power supply. This sounds like its a 32 inch lcd tv. I tried searching for a service manual for this and can't find one. If it is an lcd you need to look at the capacitors on the power supply. If they are puffed up, you will need to replace them with equal or slightly larger valued capacitors. The capacitor values are mfd and voltage printed on the capacitors themselves. You will need a soldering iron to replace them. Lay the tv, if it is an lcd, on a flat surface cushioned by a blanket. Make sure the surface is large enough to support the tv frame, as you don't want to cause damage to the panel. remove the back of the tv. There are numerous screws, and once the back is off, check the power supply pcb for puffed caps. This is the board with the power cord attached. I know in magnavox tv there is a cage covering the power supply, so remove any connectors because you will have to flip the cage housing the power supply to get to the caps. If you feel confident, give it a try. Let me know how it goes
Apr 03, 2011 | Televison & Video
Insignia TVHD30 has picture that pulls in at the sides
HELLO it sound's like you need to set the convergence. on the set.!!! or need to replace the ic chip's on the convergence board. to fix your problum. "good luck"
Nov 25, 2008 | Mitsubishi WS-55859 55" Rear Projection...
30inch insignia
Sounds like power supply problem (either poor connections or bad capacitors).sometimes they look deformed or you have to check them with an incircuit capacitor tester.
Jul 19, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture
Try a "hard restart". which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 30, 2008 | Insignia NS-30HTV 30" TV
Insignia TVHD30
I, need the exact model no. to see if you can get part for it . need also to know if it uses an external power adapter thanks
Jun 10, 2007 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
273 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
