Question about Calphalon Removable Plate Grill
Calpholon removable grill plates don't stay connected
How to replace the ignitor battery on a DCS outdoor grill
  • Open the two cart doors on the bottom front of the grill, if your DCS model has doors.
  • Remove the drip pan under the grill by sliding it forward.
  • Locate the 9-volt battery behind the grill control panel in the compartment directly below the "Ignition" button on the front of the panel. The battery is mounted vertically to the connection plate.
  • Pull the battery straight down to disconnect and remove, using pliers if necessary.
  • Hold the new battery in position below the connection terminals so that the positive (+) post on the battery is facing inward beneath the grill. The positive post is the larger of the two posts on the top of the battery. Push straight up to connect the battery.
  • Slide the drip pan back in place and close the grill cart doors.
Jan 21, 2017 | Grilling
Are porcelin flavor plates removable? If so, how?
If you're referring to Powder-Coated Porcelain Cast Iron Adjustable Grates. Yes, they are removable. They just lift off the grill. As do the tent shaped Flame Tamer/Flavorizer plates under the grill grates and above each burner. They should be removed regularly for cleaning.
Hope this helped you and Happy Grilling!
Apr 18, 2011 | Cabana Kitchens CLA480 (LP) Grill
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
How do i remove the grille to get to my radiator in a 97 tacoma
You do not need to remove the grill to remove the radiator.
If you want to remove the grille, you have to remove the two side marker lights, and then depress the tabs that locate the grill to the radiator support. Using a long tin screwdriver, depress the small tab downbward, and pull on the grill to let the grill slide off of the retainer. Start at one end, and work your way across. The retainers will stay connected to the radiator support.
Oct 19, 2009 | 1997 Toyota Tacoma
Top Plates Do Not Stay Up As They Should
Follow Up From Postee: Determined that by simply removing the back cover (phillips Head Screw) that there is a brass clamp over the pivoting bar that has an alan head screw on either side. Simply tighten both sides and the lid will stay up. Done.
Feb 11, 2009 | Adcraft SG-813
Flattens meat
Don't use the frozen setting, it uses more pressure. I only use fresh, even for frozen food, i just cook it a little longer. If you want your Steak or Chicken to stay juicy, spray both sides of the food with Olive Oil Spay (About $4 from store) before you put it in the bag (Or dip in an Olive Oil bath and wipe off excess). It will allow the food to sear, stay juicy and taste wonderful. The oil will also help allow seasonings to stick to the food. (I am the master of Rocket Grill, and even cook scrambled eggs in it. Trade secret though)
Jan 27, 2009 | Sunbeam Rocket Grill RG12
When knob is on ''Off'', should power light (red) go ''off'' too?
I have a G5 with removable plates, our red light stays on and this is correct
Nov 22, 2008 | George Foreman G5 Indoor Grill
Brevill Grill Removable plates - dishwasher safe?
Greetings jackneve,
The manufacturers specifications would indicate these plates are indeed dishwasher safe!
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Breville TG400XL Indoor Grill
G5 Handles on plates
called salton and ordered new handles for the plates
Mar 26, 2008 | George Foreman G5 Indoor Grill
Indoor Grill with removal plates Geo Foreman Grill
I can't find info on the "George Foreman" grill , model : GRP90WGWCAN
It is offered in the prime booklet of our credit card bank.
Dec 08, 2007 | George Foreman GRP4P Indoor Grill
Calphalon Removable Plate Grill Logo
26 people viewed this question
Top Calphalon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Calphalon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
