Question about Dryers
Kenmore 970 c85022-00 - Dryers
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
Jan 14, 2017 | Kenmore Washing Machines
Kenmore #970-155320 how much cold it has...cant find it its for bed bug killing experiment....
Turned to their coldest setting, most properly functioning household refrigerators can attain minus 6 to minus 10 degrees in a normal (70-78 degrees) room. Room (ambient) temperature affects cooling performance. Colder temps will cause the unit to run significantly more.
Oct 28, 2016 | Kenmore Refrigerators
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
Kenmore freezer,model # 970-155320
How much cold can this kenmore 970-155320 be,it need to be....
  • A freezer that is at or below 00F (-18oC) i wanna use it for bed bug killing.....
Jan 04, 2014 | Kenmore Freezers
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Kenmore 970-227410 Freezer Water pools in
thaw drain it may be stopped up it will make it do what u r talking about
Nov 07, 2009 | Cars & Trucks
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
