Question about Panasonic F82565y00ap Lever Oem Original Part
Door opening lever Panasonic microwave - Panasonic F82565y00ap Lever Oem Original Part
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Posted on Dec 07, 2008
  • 44 Answers
SOURCE: microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Posted on Sep 27, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
Cant open door on panasonic genius 1100w
One of the door opening parts has failed, most likely the lever or the door open button.
See this safety information and these disassembly instructions.
You will need to take the outer cover off the oven, then you can see the door opening parts.
As you try to make the door open, you can see the mechanism and which piece has failed.
You can order Panasonic microwave parts from Encompass here, and for other brands, see this parts ordering page.
For more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 29, 2017 | Panasonic Microwave Ovens
Door will not open. Nothing broken in the mechanism
Hi Glen,
Have you taken the wrapper off of the unit to open the door? You usually have to use a pencil or small screwdriver to lift up on the bottom latch head (doorkey as Panasonic calls it). These counter top models typically use a three step method to open the door. The push to open button pushes on a lever that then lifts up on the bottom doorkey. The lifting lever cracks and won't support fully the weight of the doorkey. The crack can be small enough to not really be noticeable if you are not very familiar with this problem. I'm pretty sure that this is what you will find. Let me know..
Oct 21, 2013 | Panasonic NN-P794SF Microwave Oven
Door does not open
You'll need to remove the outer cover to get to the door open button or door lever, either of which can cause this problem.
The service manual is here.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 15, 2013 | Panasonic NN-P295SF Microwave Oven
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
We need a replacement piece for our microwave. The button you push to open and close the microwave is broken.
What usually breaks is the door open lever, but the prongs on the door open button may also be worn.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel usually needs to be removed.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find Panasonic (US) parts here. If you're not in the US, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Panasonic Microwave Ovens
Panasonic F82565y00ap Lever Oem Original Part Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
