Question about Broderbund PrintShop Signature Greetings Full Version for PC
Broderbund print shop signature greetings older program won't install on my windows 8 pc
    Master:
  • 841 Answers
It will not install. That is why I kept my old xp computer. Some older programs will not run on Windows 8 and newer as they use apps to run the program. You can see of printshop has an app. As for installing the program using the cd...forget it.
Posted on Oct 04, 2017
  • 7 Answers
SOURCE: cannot remove software from pc
try Tune-up utilities 2009, its got uninstall tools in it, or if you have not installed any other programs after that day you installed Broderbund print shop, open System restore and click on the date you installed it. This will uninstall the program
Posted on Jun 17, 2009
SOURCE: Purchased Broderbund Print Shop 23.1 Deluxe. Two
Yes, otherwise you have to manually insert the Art disc every time you want to use the Art & Photos.
Posted on Oct 12, 2010
muntejaya
  • 10421 Answers
SOURCE: I cannot save as PDF
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__0ojjd43
Posted on Feb 26, 2011
thedayi
  • 95 Answers
SOURCE: I'm buying a new computer
Windows 7 professional and Windows 7 Ultimate have a "Windows XP mode". It may work without it but if it doesn't just use Windows XP mode. Which you can download here.
Posted on Mar 19, 2011
  • 17 Answers
SOURCE: I can't install Print Shop Duluxe 22 with
Hello, I cannot take credit for this solution. I found it on the Encore forums, as follows:
http://forums.encoreusa.com/tm.asp?m=37934
To summarize, though, I think there are 2 things to keep in mind:
  1. You will get a compatibility warning. You can simply bypass this by selecting "Run Program".
  2. You will have to install a "Document Converter" after the install is completed. The above forum post references a location where this can be obtained.
The information in the above forum post is a wee bit technical, but straightforward enough if you just take things one step at at time.
Good luck, it is unfortunate that as technology moves forward, we will be faced with these types of situations from time to time.
Please let us know if this was helpful to you.
Thanks ~Jim :-)
Posted on Jul 22, 2011
I had The Print Shop Signature Greetings before but it won't install on Windows 10. My PC says this program would not install on your PC.
First, you may have to accept that the older program you have to install may never work with Windows 10. The newer security fixes and updated features of Windows 10 may mean that older programs literally cannot run on modern operating systems.
HOWEVER, you may be able to install and run your program if you experiment with the program compatibility settings in Windows 10.
With your install CD in the drive, open Windows Explorer so you can see the files on your hard drive. Now select the drive letter for your CD/DVD drive to view the files on that disc. You should see a file called 'setup' or 'install' which would be the program executed to install your software. Right click on that file, and your should see a "Troubleshoot compatibility" option. Select that and then try to set the program to use settings from a previous version of Windows, like Windows 7, or Windows Vista, or Windows XP. Once you've select the version you want to try, click OK, then double-click on the file you just configured to cause it to execute. Hopefully, you'll get it installed. Good luck!
Sep 19, 2017 | Signature Computers & Internet
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
New computer has Windows 7. What version works on Windows 7?
Older programs can usually be run in Windows 7 using compatibility mode.
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Mar 04, 2011 | Broderbund PrintShop Signature Greetings...
My create a card cold is not compatable with my windows 7 computer
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. Do the same for the installer if it wouldn't install. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 13, 2010 | Broderbund American Greetings Creatacard...
Why am I unable to install my existing CreataCard Gold 5 on my Windows/Vsta? Can you please advise me?.
There are unfortunately a few older programs that are not compatible with Vista. Check on the box it will tell somewhere on it what Operating Systems it works with.
Sep 27, 2010 | Broderbund American Greetings Creatacard...
Is Broderbund Creatacard compatible with Vista?
In Vista, start the "Windows Program Compatibility Wizard".
Choose to install a "Windows XP" program, namely the Broderbund software. Vista will wrap a "cocoon" around the application, to fool the application into thinking that it is running under Windows XP, not Vista.
Apr 05, 2010 | Broderbund American Greetings Creatacard...
Printing CreataCard Platinum 7 with Vista
if there are they will be on their website, but i'm going to say you've probably made that software useless and will have to buy a new program
Jul 25, 2009 | Broderbund American Greetings Creatacard...
Does not read .sig files
Small text file that can be automatically attached to the end of e-mail messages; usually includes the sender's name and e-mail address; in work-related e-mails, the signature may also include the name of the person's company, the person's title, and contact phone numbers; some people choose to include a quote or Bible verse in their e-mail signature.
Most e-mail programs support multiple signature files; they can usually be selected from within the create new message window. Program(s) that open sig files mac.gif Mac OS tri.gif QUALCOMM Eudora Pro
windows.gif Windows tri.gif QUALCOMM Eudora Pro
tri.gif Microsoft Outlook
tri.gif Microsoft Outlook Express
Broderbund Sign File Popularity 3.gif Average Category Image Files File Description Image format used for signs and posters created with Broderbund graphics software, such as PrintMaster and The Print Shop; can be opened with the program that created the file and possibly with other Broderbund programs or versions, but compatibility is not guaranteed. Program(s) that open sig files mac.gif Mac OS tri.gif Broderbund The Print Shop
windows.gif Windows tri.gif Broderbund The Print Shop or PrintMaster
Jul 02, 2009 | Broderbund The Print Shop 20 Deluxe for PC
Contact Broderbund for support This problem was caused by a compatibility issue between this version of Windows and this version of PrintShop Deluxe. This program was created by Broderbund. Recommendation...
I used a 14 disk ClickArt 200,000 edition with my older computer. Now I have a new Windows 7 Computer. Is not this 2000,000 edition compatible with my new Computer.?
Feb 19, 2009 | Broderbund The Print Shop 20 Deluxe for PC
Broderbund PrintShop Signature Greetings Full Version for PC  Logo
89 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
