Question about Pride Jazzy 614 Hd JAZZY 614HD
My jazzy 614 h d turns off while moving forward . press horn button & turn it on , it
5 Suggested Answers
SOURCE: Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Posted on Jul 30, 2010
  • 39 Answers
SOURCE: the jazzy 1113 will not start, when you press the
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Posted on Nov 11, 2010
  • 50 Answers
SOURCE: not sure witch jazzy chair
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Posted on May 05, 2011
gewiz
  • 1271 Answers
SOURCE: Have a jazzy pride 614 and it is hard to get it to back up and it
hi, where are you please ? ... there can be number of reasons for this, the most common...
1. the reverse logic of the controller is breaking down..
2. the joystick mech ...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 10, 2015
Moves in reverse, but why not forward?
The Joystick gimbal has dirt or grim in it, need new joystick.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 15, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
Jan 27, 2016 | Pride Jazzy Select Elite
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Jazzy 614HD goes into lockout. We can get it out of lockout but goes back into lockout at any movement of the chair........
Make sure any seating system is completely down and in DRIVE position. When chair is unlocked, wait 5 seconds, shut chair off, wait 5 seconds, turn chair back on. Each time you turn the chair on you need to wait 5 seconds for the POST to complete before moving the joystick.
Oct 14, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
Mar 18, 2013 | Pride Mobility Products Pride Jazzy 614
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
Will not turn on when I push the power button
This indicates the chair is in lock-out mode.
Use an XLR lock-out key or manually unlock the controller by holding the power button during the on cycle for 3 seconds, then push the joystick forward til it beeps, then pull it back until it beeps and then release it. You should be unlocked.
Sep 01, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I need directions to unlock the controller arm for my jazzy 614 HD.
kari with the jazzy try turning the power on and immediately push the horn button twice I think this will take it out of sleep or lock out mode. If that doesn't work turn the power on and immediately push the joystick forward until you hear a beep then immediately push it to the rear until you hear another beep then release it to the center. Good Luck Hope this helps
Oct 29, 2010 | Health & Beauty
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy 614 Hd JAZZY 614HD Logo
19 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
