Question about GE WJRR4170E Top Load Washer
Squeeky agitation (loud)
WJRR4170E1WW top load clothes washer. Fills fine, drains fine, spins fine...loud squeek on left side of machine when agitating. How can I fix this?
  • Anonymous Mar 24, 2014
    Loud squeeking on agitation cycle
There are 4 rods that the tub hangs from. the plastic pieces at the top of the rods are supposed to wear in, but many of them continue to squeak. had the same problem with mine for the last 4 years. in year 1, the GE repair guy said this is common and showed where to lubricate. open the front panel (stick a screwdriver or stiff butter knife to depress the 2 clips.) you'll see the rods. (altho the back ones are kind of hidden). a quick spray of silicon will quiet the squeak. usually lasts about a year.
Posted on Nov 19, 2009
    Sergeant:
  • 306 Answers
Sooner or later someone that cured this problem may provide his solution. Meanwhile, if you can't wait, you or a technician will have to pull the machine out far enought from the wall to remove the rear panel to get eyes and ears inside and closer to the squeek. That is the way it is done normally for a first time problem. You may get lucky and see the problem or be able to tell this group more exactly where the squeek is is being generated.
Posted on May 03, 2009
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
Top load won't agitate or spin
If it is a direct drive (no belt) Your motor coupler is broken. The washer would make a grinding noise but do nothing. Basically it is like a belt it connects motor to tranny. It is a fairly inexpensive part $20-25 retail.
Apr 25, 2009 | Washing Machines
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
My machine will nto agitate or drain, but fills fine.
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Jan 07, 2009 | GE WWSE5200B Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
GE WJRR4170E Top Load Washer Logo
380 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
