Question about Kustom Deep End 200HD 200 Watt Bass Amp Head
Diagram for kustom deep end de 200hd bass head
Does anybody have the deep end 200 hd full diagram? I have the owners manual and the diagram in there its not enough to fix the power problem of my kustom
Conseguiste el diagrama ?
Posted on Jun 26, 2015
2 Suggested Answers
  • 5603 Answers
SOURCE: my 200hd head is not
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
Posted on May 06, 2011
I have a crate 16 channel mixer and when i power it on i cant usually get sound through the channels when i hook up a mike sometimes the low z input works and sometimes not. the regular line in for the mic...
If you have already spray cleaned the pots and switches then the problem is almost surely bad solder connections on the board. This happens often if unit travels a lot with no case. Resolder all pots, switches and jacks and check copper trace for breakage at these places. In case of broken trace hard wire across breakage.
May 11, 2017 | Kustom Deep End 200HD 200 Watt Bass Amp...
Kustom groove 310c bass amp
What is your question?
Nov 04, 2011 | Music
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
Kustom Deep End 200HD 200 Watt Bass Amp Head Logo
179 people viewed this question
Top Kustom Music Experts
Michial Gueffroy
Are you a Kustom Music Expert? Answer questions, earn points and help others
