Printer cover open error
Printer cover open error on ir 1600 can any one suggest me on this
  • 523 Answers
Check the sensor that touch the cover when u close it,
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Apr 24, 2009
Error msg check cover closed, but it is closed. no way of going on
Check to see if there are any lugs on the lid/cover which may not be articulating with the relevant switches inside the printer.
Feb 18, 2015 | Canon iR 1600 Copier
How to sole Canon IR 1600 check printer cover error
(1)
If one of the doors on the Cassette Pedestal is open, then the main unit will display the 'check printer cover' message. Check to make certain all of the doors on the Cassette Pedestal are completely closed.
Note: These doors are located on the lower left side.
(2)
In service mode: (DORSW1/DORSW2) tested good.
Solution :
It may be necessary to refit the vertical path guide for cassette if it was not hitting the retry sensor, PS152, in the cassette unit.
Note that every cassette has a retry sensor (PS152).
(3)
Paper is "crunched" into the Retry sensor.
May 15, 2014 | Canon Office Equipment & Supplies
Canon ir 1600 error check copier cover
If the cover is closed, check the sensor or switch under that door. seems that the cover isnot hitting it.
Apr 30, 2014 | Canon Office Equipment & Supplies
DEAR I AM FACING PROBLEM IN IR2000 ROM ERROR SO I NEED FIRMWARE FOR THIS MODEL OR GIVE ME A SOLUTION. THANKS
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software/or replace the DIMM Assembly.
When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Service Mode=Additional Functions #
Aug 05, 2010 | Canon iR 1600 Laser Photo Printer
Ir 1600 . e100
When the scanner motor is started up, the BD input signal does not arrive
within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal
cycle is not within a specific range (±2%) for an equivalent of 10 mm (print
distance).
cycle is not as indicated (±2%).
During the period after the power switch has been turned on or
the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed
Mar 30, 2010 | Canon ImageRunner 1600 Copier
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Nov 23, 2007 | Canon imageCLASS D860 All-In-One Laser...
229 people viewed this question
k24674
jasbo
jasbo
