"Change Drum Soon" is remaining on screen even though a new drum has been installed
"Change Drum Soon" is remaining on fax screen even though a new drum was installed. How do I remove this message from the fax machine?
Just put a new toner cartridge in fax and now I get message saying "change drum soon" How do I fix this?
First make sure your toner cart is the right one for your machine.. Try another cartridge to verify that even though the cart is new does not mean it does not have a problem. I would check all the silver contacts on the drum unit to be sure they are clean. use 90% alcohol to clean them, using a cloth to wipe them.
Jun 08, 2010 | Brother IntelliFax-2820 Laser Fax
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
Apr 09, 2010 | Brother IntelliFAX 4100 Laser Fax
Our fax machine says "change drum soon" even though we changed it yesterday. What is causing this? Thanks
When you installed the new drum, there is a sheet in the box that tells you how to reset the drum life counter. Did you perform this procedure when you installed the drum?
If you don't have it just open the front cover and press options then select 1 for drum replacement.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother IntelliFax-2820 Laser Fax
Change drum soon will not clear after new drum inserted
Reset of the drum counter
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Jun 10, 2008 | Brother IntelliFAX 2800 Laser Fax
"CHANGE DRUM SOON"
To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
744 people viewed this question
k24674
jasbo
jasbo
