Question about Farmall Tractor C ,super Av, Complete Gasket Set
Head bolt torque on 1953 super a - Farmall Tractor C ,super Av, Complete Gasket Set
Identify engine in 1953 willys jeep
Engine Data: 4-134 F Head Motor (All Years)
Engine Type: 134 CID (2.2L) F4-134 Hurricane 14
Number of Cylinders: 4
Cubic-In. Displacement: 134.2 cu. in. (2199,53 cm 3)
Horsepower: 72@4000 rpm
Torque: 114 lb-ft. (15,7 kg-m.)
Compression Ratio: 6.9 to 1
Valvetrain: F-Head
Jun 30, 2014 | 2006 Jeep Cj
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
How much torque on head bolts&intake bolts on 1990 thunderbird super coupe
Here's a link to the head bolt torque specs.Here's the intake bolt torque.
Jan 13, 2013 | 1990 Ford Thunderbird
Torque specs for 99 f350 head bolts on 5.4l
Check this information for 1999 FORD TRUCK F350 SUPER DUTY P/U 4WD 5.4L EFI 8CYL and keep in mind that cylinder head bolts must be replaced with new ones. They are torque-to-yield designed and cannot be reused.
Tighten the cylinder head bolts in the sequence shown in three steps, as follows:
  1. Step 1-27-31 ft. lbs. (37-43 Nm).
  2. Step 2-tighten an additional 85-95 degrees.
  3. Step 3-tighten another 85-95 degrees.
Image Zoom Link : large/0900c152801e5215.gif
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Ford F-250 Cars & Trucks
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Need torque spec on back 3 bolts of hub assembly on 2003 silverado 5.3 v8.
I belive that your talking about the bolts that sucure the hub to the knuckle . 50 TO 60 FT LBS is good its not a super critial spec unless for some other reason they are comeing loose witch wouldn't have anything to do with the torque spec anyway . Torque is determined by the diamater and tread pitch as well the grade of the bolt so a grade 8 bolt is much harder and stronger then a grade 2 bolt and the thread pitch is lower on harder bolts so they have more threads per inch . You can also tell by looking at the head of the bolt the more lines you see the harder the steel the bolt is made out of is So like i said its not super crictial and if there lock washers make sure you but them back ware they came from
Jul 14, 2011 | 2003 Chevrolet Silverado 1500
Torque specs for cylinder head on a 200 ford focus with 2.0 ltr single overhead cam. and for connecting rod... Thank you much.
  1. CAUTION: Always install new cylinder head bolts. NOTE: Lubricate the cylinder head bolts with Super Premium 5W 30 SAE X0-5W 30-QSP or equivalent meeting Ford specification WSS-M2C153-G prior to installation. Install the cylinder head assembly and tighten the cylinder head bolts in the following sequence.
  1. Tighten all bolts in a single sequence to 50 Nm
  2. Back the bolts off 1/2 turn.
  3. Tighten the bolts in sequence shown to 50 Nm .
  4. Rotate all the bolts in a single sequence an additional 180 degrees in two steps of 90 degrees each.
9 3 1 5 7
8 6 2 4 10 sequence for head
Spec for rod 38Nm
May 07, 2010 | 2000 Ford Focus
Head bolt torque
They have this listed under a 2007 E-350 but I new it couldn't be. Any how the torque specs are as follows. The big bolts 1-26 are to be torqued first they are torqued to 120 ft. lbs. then rechecked to 120 ft. lbs. Then tightened 1/4 turn or 90 degrees. After that that loosen all the bolts up till the washers are loose again then perform the exact sequence all over again. After that tighten the small bolts on the outside part of the cylinder head all 7 of them to 20 ft. lbs. Good luck.
Apr 11, 2009 | 2007 Ford E-350 Super Duty Length XLT
Farmall Tractor C ,super Av, Complete Gasket Set Logo
14 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
