Question about GE Ovens
F76 error code on ge oven - GE Ovens
  • GE Master
  • 12,061 Answers
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Posted on Aug 22, 2015
2 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: My GE oven gives error code of F3 and F5
Thank you for contacting Fixya.
It's possible it could be the senser, just two screws hold it on and the wires unplug with a connector.
As to understand it in details whether the sesor is the bad part you can use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
You can get a cheap ohm meter at Radio Shack or any hardware store. If your oven sensor tests good, then your control board would need to be replaced.
That would help to resolve the issue.
God Bless.
Posted on Jul 13, 2009
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
GE oven displays an F 7 error message
Hi Mark, Why not search online for this error code + ge oven? You'll get the info you need but don't necessarily want!
Jul 15, 2015 | GE Ovens
I have error F76 and the oven is beeping.
MAke and model needed to find error codes
Jan 30, 2015 | Ovens
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
6,794 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
