Question about Sanyo TRC-8080 Desktop Cassette Voice Recorder
Continuous beep a continuous beep when I try to dictate
    Problem Solver:
  • 6 Answers
Hello. The TRC8080 will coontinously beep when trying to record if the tab switch (this is described in the service manual a Tab Switch S3, S4) fails. The tab switch consists of two leaf switches one is so the machine know there is a tape in the machine and the other check for record protect. Over a period of time thee canbecomebent anwill not always connect when a tape is in. This wll result in you either not being able to play a casette or not being able to record depending on which one fails. These can only be replaced as a pair. If it is not the tab switch which has failed then the cassette tabs on the top may be bent in slightly which means you will need to replace the cassette.
If the tab switch has failed and you dont want to pay for a repair you take the 5 screws out of the back of the machine, lift the top cabinet off (disconnect the single molex connector) and short the switches together. (Solder is best) this will leave the switches perminatly in the 'on' position meaning you can dictate away.
Remember if you shoose to short the switches together the motor will run as soon as the cassette lid is closed and the machine is on. This may make the motor fail a little bit earlier than normal.
Posted on Aug 19, 2009
T6520 emachine won't turn on, lights and fan work. Beep code
Hi, you are having a problem with your add on cards, try to pull out everything that you have add on to you PC, then try to put 1 by 1 and try to turn on. If it beep once its OK, but if it's continue then the add on cards are the defective.
Oct 08, 2012 | E-Machines eMachines Desktop PC
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
While dictating on the Lanier VW-260, the machine suddenly starts beeping - a rapid series of beeps, as if the tape is at the end. We thought maybe it was a bad tape. But that is not the case. It keeps...
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Apr 14, 2011 | Lanier 260T Desktop Cassette Voice...
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
Remove a memory module.
If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module.
Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
If the computer has a graphics adapter, remove it.
If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step.
If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
Remove a PCI card.
If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card.
Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket.
If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing.
Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case.
May 12, 2009 | Intel Motherboard
Narly
  1. Clean cooling components that have become clogged with dust. If beeping persists, continue to the next step.
  2. Remove a memory module. If the PC stops beeping, the memory module may be bad, is the wrong type of memory for the motherboard, or was not fully seated/connected. Try reseating the memory into the socket to see if a connection was the problem, otherwise replace the module. Remove each memory module, replacing the one that was previously removed. Once all modules have been checked, if beeping persists, continue to the next step.
  3. If your computer has a graphics card, remove it. If the beep code changes or continues with the same beep pattern, the video card may still be good. reseat the video card into its socket and continue to the next step. If the beep code goes away, the video card may be bad. Try reseating the video card, making sure it is fully locked into the connector on the motherboard. If problems persist, replace the card.
  4. Remove a PCI card. If the beep code goes away, the card may be bad. Try reseating the card into its connector on the motherboard. If problems persist, replace the card. Remove each PCI card, replacing the one that was previously removed. Once all cards have been checked, if beeping persists, continue to the next step.
  5. Disconnect hard drives and CD/DVD drive cables (IDE/ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems persist, the drive itself may be bad and may need to be replaced. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. Once all connections have been checked, if beeping persists, continue to the next step.
  6. At this point, the problem probably involves the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly.
Jun 09, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Is it possible to stop recording without opening a new file?
Sanyo TRC-8080 Desktop Cassette Voice Recorder Logo
97 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
