Kenmore wash 11020022012 grinding sound when agitating. black plastic debri under washer
5 Suggested Answers
JR JR
  • 116 Answers
SOURCE: Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Posted on Nov 30, 2008
  • 113 Answers
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
Posted on Mar 03, 2009
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Posted on Aug 13, 2009
Testimonial: "Thank You! The diagnosis confirmation and repair video helped. There were some differences between my Washer and the repair video, but figured it out"
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Kenmore model 110 22632 100
The coupler between the motor and the trans is history. The part only cost about 15. Pull your washer away from the wall and tilt it back against it. See the black deposits on the floor? That is the debris of the coupler - rubber and plastic . Take off the water pump = remove the clips and let it hang. Next remove the screws in the clips for the motor and pry the clips off. The motor will now come away from the trans. Remove the damaged coupler parts and replace them with the new one. Reassemble the parts and wash your clothes.
Jan 13, 2014 | Washing Machines
Kenmore 23032 top load direct drive washer will not agitate or spin, but still does drain - is this the clutch or drive motor?
no replace coupling # 285753 double shafted drive motor ... coupling attatches motor to transmission look for black rubber and off white plastic chuncks under washer.......
Jan 31, 2011 | Kenmore Washing Machines
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only...
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Dec 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Apr 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washer is making a grinding noise. It want spin or agitate.
sounds like ur shaft is stripped motors about 100 bucks ur call prob better get a new one
Dec 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore-80series washer -the agitator needs to be replaced.
remove the agitator cap,,remove the plastic seal under just pull straght up with your hand,,inside agitator theres a nut,,remove thi 1/2 inch nut with ractet and pull agitator straight up
Dec 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
