Question about Garden
2500 excel 6.5 hp briggs & straton pressure washer residential
Motor runs great . very little water pressure coming out of wand. my hose & wand is new , no blockages or kinks. great water pressure from water hose to pump.
  • 3600 Answers
SOURCE: honda gx270 pressure washer. water is not coming out strong.
did you check the inline screen for dirt?
Posted on May 24, 2009
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
  • 32 Answers
SOURCE: no water is coming out of the pressure washer
i think you have a blocked nozzle on the lance, get a paper clip and push it right down the end and wash out.
Posted on Jul 04, 2009
brado83
  • 106 Answers
SOURCE: Pressure washer starts then shuts down in 2 seconds
hey mate,
It sounds like your bypass valve/unloader valve is sticking when pressure builds up in the lance,hose and head the pressure cleaner changes to a recirculate mode so it does not blow out hoses or seals or causes any damage to the unit, the bypass valve is the component that activates this sequence if that valve is stuck it will just try to continue to create pressure which in turn puts load on the engine and stalls it...
That is why it starts up straight away and only when it builds up pressure is when the engine stalls.
You would be best taking this to a qualified pressure cleaner technician as there are alot of little parts and orings plus the the head will need cleaning up and the bypass valve lubed, they may not of seen this at the service as it is hard to test a unit without the suited hose and lance... Often use will help this problem when a unit sits for a period of time that will cause issues such as this!!!
Regards
Brad:)
Posted on Sep 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Posted on Jun 04, 2010
I have an excell pressure washer vr2500 with a 6.5 hp Briggs and Stratton motor after pouring gas into empty gas tank see gas leaking from carburetor
YOU HAVE A FLOAT IN THE CARBURETOR THAT MAY BE STUCK THERE IS A SMALL NEEDLE VAULE THAT ALSO MAY BE STICKING YOU CAN GET A REBUILT KIT FOR THE CARBURETOR
Feb 23, 2014 | Cam Spray 25006BX 2500 PSI Cold Water Gas...
Why will water not flow through hose into the spray gun with the washer not started as well I started the power washer and the water still does not come out.
My Craftsman pressure washer has a filter in the hose tp the pressure wand. I found I must have had some dirt in my garden hose and these filters were plugged. No pressure at all till I cleaned them out.
Jul 04, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Pressure washer won't deliver pressurized water.
sounds like you have a blockage maybe in your water hose ,ideally your water hose should be around 25 feet..or you may have an o ring in the gun where the tip goes.. is broken..that will affect your pressure..check also filter where water hose connects to the pump make sure thats clear
Sep 30, 2017 | Briggs & Stratton Briggs Stratton 1800...
I have a Briggs & Stratton Pressure Washer it was just working Fine THEN the water stopped coming out of the wand? Any Suggestion
Remove the tip and pull the wand trigger without the tip in. If water comes out then your tip is clogged. Clean the tip and reinstall. Or try a different tip.
Its also possible that there is a kink in the supply hose to the unit.
Try these first, it should solve the problem about 90% of the time
Jul 02, 2011 | Briggs & Stratton Pressure Washer...
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
Sep 19, 2009 | Briggs & Stratton Garden
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
