Question about Siemens Lands Phones
Gigaset 4010 no signal - Siemens Lands Phones
Base is flashing and cannot dial out
HERE'S THE LINK TO THE MANUAL.
The handset is either too far from the base or it needs to be registered. The instructions are in the manual.
http://m.gigaset.com/medias/sys_master/A31008-M2050-L101-1-7619_30-10-2008_en_GBR.pdf
Dec 25, 2012 | Siemens Gigaset 4010 Cordless Phone
Gigaset showing no base n hand set display, how do we fix it?
Off hand I would say your battery is totally dead
May come back with an overnight charge
Jan 30, 2011 | Siemens Gigaset 4010 Cordless Phone
The best way to discharge the handset?
Unplug your telephone cable from base, on the handset press the talk key and just let it sit there should take a couple of hours or so.
Nov 15, 2010 | Siemens Gigaset 4010 Cordless Phone
I have Gigaset AL14H (base and other remote one) My problem, both sets don't show caller number when I connect them in my home. I tryed them in another zone and they are OK. Is this depend on the...
This is because your service provider dont have this caller ID facility.
Some service provider by default have this facility activated but some service provider we need to activate this facility.
Please call your service provider to activate this facility.
Thanx
Jul 28, 2010 | Siemens Gigaset 4010 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
The screen on the hand set displays searching
PIN restore Gigaset 4010/4015 base
If the PIN code forgotten your Siemens Gigaset 4010 / 4015 base (Classic / Comfort / Micro) then follow these steps to create the reset:
* Take the power cord out
* Press the button and on the bottom of the base and hold
* Insert the adapter into the outlet, hold the base button
* Wait 30 seconds, keep the button pressed
* Wait 10 more seconds and remove the adpter from the outlet
* Put the adapter back in
The unit is now reset and the PIN code is 0000.
Mar 22, 2009 | Siemens Gigaset 4015 Cordless Phone
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
Answering machine
Unfortunately the 4010 model does not have a built in answering machine but does have features to work with your local telephone companies voice mail. If you want to keep your same phones and get a base with a built in answering machine you will need to replace your 4010 base with a 4015 base (up to three handsets), or a 4215 base (up to four handsets). But don't toss out your old base, you can use it to extend your range if you ever use a 4200 series handset that will allow you to register each handset to up to four seperate bases simultaneously to extend the range. You can buy the 4015 or 4215 base only and save yourself some money. You can google Siemens cordless repair or go to the Siemens website to find a few options.
Aug 12, 2007 | Siemens Gigaset 4010 Cordless Phone
Lands Phones Logo
55 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
