Question about Kenmore Elite 45986 Front Load Washer
My washing machine front panel will come on, will not do anything
My front panel light ups like it is going to work, but the water will not run or anything, just sits there and hums! Its like it is a problem with the water, but we have plenty of water pressure, I need help! I know it is a kenmore, possibably a LG
  • Anonymous Mar 14, 2014
    i don't know what each method of washing is on front panel I have no instructions on how to run the machine
  • 113 Answers
Your water valve is probably stopped up or gone bad
Posted on Apr 24, 2009
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
NEC NW-452 Washing Machine will not run a Hot Wash
by memory it is located at the lop of unit, where u attach the inlet hoses 2 the machine. u need to remove inlet hoses first with water turned off, then undo 2 screws at back of washer holding plastic panel that covers water valves and electics. it unclips off, i always have trouble myself. once u have that panel off remove wires to hot valve ( that is the 1 that had the hot water hose attached to it) put your tester on the terminals. if u get a different continuity reading compared to your cold it is faulty. if it is the same your computer at the front of unit is faulty.see how u go but remember turn off the power b4 u work on it! dont want any acciedents. please reply back for more help. good luck!
Mar 10, 2010 | Washing Machines
Control locked light on no buttons work
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a he2 kenmore front end loader washing machine...it stops mid load and flashes F20
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore Front Load Washer on the blitz
remove bottom panel and ck pump for obstruction especially if water is still in tub
Jul 21, 2008 | Kenmore 43142 Front Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Filled with water overnight
Hi When I plug it in is there any light on the panel that will come on without hooking it up the water lines???
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
Doesn't heat up the water, no matter what program chosen
Heating element or a thermostat is open cuircit. Regards Appliance Doctor
Feb 01, 2007 | Miele WT945 Front Load Washer / Dryer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
