Question about Coffee Makers & Espresso Machines
Nespresso magimix m150 just drips coffee...really slow, but steamer works fine. Missing the hex. key to remove cage. Any ideas ?
2 Suggested Answers
SOURCE: Nespresso Magimix M300
Try rescaling the machine.  The following is a PDF of the instructions:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Posted on Apr 14, 2009
Had a nespresso magimix for xmas.orange light indicates needs descaling' surely not already'the coffee parts working but the steamer isnt'hardly used steamer. any ideas?
Pretty simple from my vantage... YOU THINK IT IS DEFECTIVE: TAKE IT BACK AND EXCHANGE IT FOR ONE THAT BEHAVES THE WAY YOU THINK IT SHOULD...
As for me I'd descale it... and consider getting a filter
Carnac the Magnificent
Feb 04, 2017 | Nespresso Coffee Makers & Espresso...
How do I disassemble my magimix m100
You will need a special 0 shaped socket, Nespresso will mend 0800 42442
spare drip trays, ater tanks and Nespresso capsule catchers available from
Magimix Spares Parts from BBS Ltd
May 21, 2014 | Keurig Coffee Makers & Espresso Machines
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
May 15, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso essenza repair
You can contact Nespresso and they will advise. You will of course need to change the area to the country you live in.
https://www.nespresso.com/uk/en/contactus
May 05, 2014 | Magimix Coffee Makers & Espresso Machines
I am missing the hexagonal key for the D150 Nespresso machine necessary to remove cage, where can I find one
Sept 2012--
I had the same problem. I purchased a used D150 and wanted to make sure it was clean before using it but it was missing the special hex key to take off the nozzle part. Here is my fix-
-Remove the water tank
-Turn the whole machine upside down. You want to remove the stainless steel square plate that holds the nozzle assembly in place. It is held there with 4 security screws. If you don't have a special security screwdriver go ask for one at your local hardware store. Get one with multiple tips as there are a few different ones. Don't try to use a regular screwdriver.
-With your new security screwdriver remove the stainless plate. Under each security head screw should be a lock washer- don't lose them.
-Under the plate should be 4 flat washers- don't lose then.
-With the plate removed you can now use an adjustable wrench to remove the hex washer which holds the nozzle assembly in place.
-Once removed the nozzle assembly will have a small rubber washer/gasket in the center- do not lose this!
-Clean all your parts---I just cleaned the rubber gasket with a cloth with water and put the whole nozzle in boiling water then cleaned it up a bit.
-Put everything back like it was and tighten well.
My used D150 works great and makes an awesome espresso!
Dwight
Sep 01, 2011 | Nespresso D150 Espresso Machine
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
My magimix coffee machine is so slow producing the coffee. please let me know what you think it is thanks
Hi Tracy. Fill the pot with half vinegar and half water and run that through the machine without any coffee. This will clean it on the inside and the speed will be back to what it was when it was new. Joe
4 thumbs up please. ty.
Nov 04, 2010 | Nespresso D290 Espresso Machine
My magimix coffee nespresso machine has just been descaled but still has flashing lights - how can i stop the flasing lights
Thanks Tish3030! By far the most helpful answer! The manual did not help at all. Besides, I can get the manual anywhere on the internet. :p Removing the tray worked! Genius!
May 31, 2010 | Magimix L'Expresso Espresso Machine
Manual instruction in pdf doc
The manual can be found at the following location:
Mar 09, 2009 | Nespresso D300 Espresso Machine
Sep 03, 2008 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
110 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
