Question about Sony VAIO Computers & Internet
Touch driver f 134 - VAIO Sony Computers & Internet
How to fix okidata c 711 error code 134
Error code 134 on the OKI C711 refers to the white ribbon cable that plugs into the Black LED head. If it has come out of the head then check that the silver contacts are in good condition and none are touching each other. If any of them are touching each other then its a certainty that fuse F12 on the main board will have blown. If they are good then push it back in but this must only be done with the power off. I cant remember whether the 711 has a plug on the end of the cable or just has silver contacts. If F12 has blown then you cant replace it as its part of the board. Only a pcb repairer can change it or fitting a new board.
Dec 08, 2016 | OKI Office Equipment & Supplies
93 ranger a/c retrofitted to r-134 how many ozs of 134 sould I install
A good place to start is 80 percent of the original charge. IE: if your truck took 2.25 lbs of r-12, then multiply 2.25 x .8 = 1.8lbs x 16oz = 28.8 oz.
Jul 03, 2014 | 1993 Ford Ranger SuperCab
DOES THE 95 TAKE 134 FOR THE AIR THANKS
all 95's use r-134.
any older cars that have r-12 should be converted to r-134.
most auto parts stores sell the package to convert them.
Jul 27, 2010 | 1995 GMC Sierra
1999 gmc Jimmy only Blows hot air. Diverter actuator is moving and working. Even when compressor starts all pipes are hot. Check 134A and was low. When put in less than a can the compressor would cycle on...
When recharging the ac you need to recover the old refridgerent. That means you have to take out all the old 134 and replace with new 134. On the engine sticker under the hood should tell you how many pounds of 134 it takes. When put in the 134 make sure your ac is on high.
Jun 30, 2010 | Cars & Trucks
My 97 2.0 jetta's a/c went out without warning. The compressor doesn't come on or anything. I thought it might be a fuse. Can you tell me where it might be located? Thank you.
It's in the fuse box under the driver side dash, usually a 30amp fuse. There is also a relay for the A/C, it is in the fusebox also.
May 21, 2010 | 1997 Volkswagen Jetta
Need driver for naxa mp3 for vista
I only see an update on Naxa's website for a NX-122 and NX-196, so the 134 may not be Vista compatible. Some manufacturers updated SOME of their players to be Vista compatible, but not others. To be absolutely sure, I would e-mail them at support@naxaelectronics.com. I just shot them one myself - I'll see if they respond.
-Tha Mp3 Doctor
Dec 25, 2008 | SanDisk Sansa e200 MP3 Player
Computers & Internet Logo
14 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
