Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Lacie Drive making awful noise!
I just purchased the Lacie D2 Quadra 500GB drive... Plugged it in for the first time yesterday and began backing up my whole system. After about 2 or 3 hours of being connected to my MacBook Pro, the Lacie disk started making an awful noise that very much resembles that of a blender blending up a smoothie. It's very loud and intense. I don't know if the disk will mount because I am afraid to leave it plugged into my computer for very long for fear it will explode or short out my computer, or something of that nature. I don't need the info on it because I have not yet deleted anything off of my computer, but I do need to know what the heck is going on. I have the WORST luck with hard drives... Help! thanks so much!
  • OnaScout Nov 02, 2007
    Similar problem with the 500GB d2 Quadra -
    When it wakes from sleep, it makes that "blender" noise (more like a coffee grinder IMO). Working with eCost on a solution, but they don't have the, ahem, best customer service in the world...
    -tyler
    Novelist:
    Champion:
  • 382 Answers
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. If the drive is grinding like you say, most likely the disk is physically damaged. If this is something you experience often, maybe you should consider power conditioners. if the drive is being moved around alot, you should be gentle with it in transit. Drive enclosures, look rugged and have flashy lights and metal enclosures, but should be treated like babies. Drives are feircely sensitive. They should be padded, kept away from magnets, and treated like laptops. Hope this helps.
Posted on Oct 02, 2007
SOURCE:
Lacie d2 Quadra 750gb HD, making werring,clicking noise.
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
May 13, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Power not getting to my lacie 320GB D2
Same here. I pulled the drive from the case and swapped it with another and the drive works fine. Must be the control board inside the case. Where can we find the replacement board?
Feb 04, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
1,899 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
