Question about Cisco Linksys CM100 Cable Modem Modems
I need a SSID. I'm connecected to network 3 - Cisco Linksys CM100 Cable Modem Modems
My Acer mini computer says won't connect to the internet it says limited
(1) Right-click on the wireless network icon next to time/date and select 'Open Network and Sharing Center'. Click 'Change Adapter Settings'. Right-click 'Wireless Network Connection' and go to properties. Uncheck all the boxes except for 'Internet Protocol Version 4 (TCP/IPv4). Now click OK.
(2) Sometimes this can happen if the SSID has been changed and will need to reset this. Simply delete the old SSID from the list of networks in the "Wireless Network Manager." Open the Control Panel ' Network and Sharing Center and click "Manage wireless networks." In the opened window, select the network with the old SSID and then click on "Remove". Now create a new network connection.
(3) Check the Acer site for an update to the wireless driver.
Aug 26, 2014 | Computers & Internet
Tip
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
on Apr 05, 2010 | Computers & Internet
What/where is ssid number on galaxy tab3?
The SSID is the Name given to the Wireless-Connection you want to join. Browse your Router-Configuration for these information.
Jul 20, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
I have a new psp and and to connect to the internet i need a ssid code but i didnt get one when i bought it
A service set identifier (SSID) is a name that identifies the network. To connect to a wifi network with your PSP follow these steps:
1. Flip the WLAN switch to 'ON'
2. Select Network Setup from the main menu after that select the Network Settings
3. Select Infrastructure mode > Create new connection
4. Select Scan and choose your WiFi`s SSID (name)
Mar 17, 2011 | Sony PlayStation Portable (PSP) Console
How to get internet.
You can try to connect to the internet wireless using your wireless router however, you need to know the Network Name (SSID) and the Network Key of your Router. You can find that on the router settings page. Heres how you can connect your Wii
1. Go to Wii settings
2. Internet connection settings
3. Search for an AP (Network Name or SSID)
4. Input security key (Network Key)
Thanks for using Fixya.
Jan 24, 2011 | Nintendo Wii Console
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a...
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
I just bought a belkin wireless router. it is a wireless G MIMO Router. i have set it up, but the number i have to type in on the address bar, it comes up 'nothing to display' i have no idea what else i...
gunja
Rank:wizard_s.gif Wiz
Rating: 85%, 88 votes hi,
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
2.The settings to Wireless section of Router appear.Click Channel and SSID.
3.Changing the Wireless Network Name (SSID)
To identify your wireless network, a name called the SSID is used. The SSID is your network name. The default network name of the Router is Belkin N1 Wireless followed by six digits that are unique to your Router. Your network name will look something like Belkin_N1_Wireless_123456.
You can change this to anything you choose, or you can leave it unchanged. Keep in mind, if you decide to change your wireless network name, and there are other wireless networks operating in your area, your network name needs to be different from other wireless networks that may be operating in your area. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
The change is immediate. If you make a change to the SSID, your wireless-equipped computers may also need to be reconfigured to connect to your new network name. Refer to the documentation of your wireless network adapter for information on making this change.
4.Changing the Wireless Channel
There are a number of operating channels from which you can choose—in the United States, there are 11 and in the United Kingdom (and most of Europe), there are 13.
In a small number of other countries, there are other channel requirements. Your Router is configured to operate on the proper channels for the country in which you reside. The channel can be changed if needed. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks.
Select channel from Wireless Channel drop-down menu. Click Apply Changes.
5.Using the Wireless Mode Switch
This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled.
1) 802.11g only
Setting the Router to this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
2) 802.11g & 802.11b
Setting the Router to this mode will let 802.11g- and 802.11b-compliant devices to join the network.
3) 802.11n & 802.11g
Setting the Router to this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
4) 802.11n only
Setting the Router to this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
5) Off
This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
6. Using the Broadcast SSID Feature
Note: This advanced feature should be employed by advanced users only. For security, you can choose not to broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
The change is immediate. Each computer now needs to be set to connect to your specific SSID; an SSID of ANY will no longer be accepted. Refer to the documentation of your wireless network adapter for information on making this change
sahil101
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes open the the console page of the wireless router by typing this ip address on the address bar in the internet explorer.
192.168.1.1
it will open the console page of the router.on the left hand side
u will see an option which says wireless settings.click on
wireless settings.then u need to look for the option which says
wpa security passphrase,just put the passphrase there n
click on apply,ur wireless connx will be secured. Selah :-)
Sep 14, 2008 | Computers & Internet
Cisco Linksys CM100 Cable Modem Modems Logo
21 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
