Question about Dell 2200MP Multimedia Projector
Dell 2200mp searching for signal
Our projector can't find a signal from any pc or laptop. we'll all using windows xp pro. it's out of warranty and there doesn't seem to be any place to have it repaired. I'm willing go in if I have to.
  • ema2s2 Nov 25, 2007
    i have the same problem .my" dell projector" shows a message " searching for signal" it does not detect the signal- and i try it on diffrent pc's.
  • PWerth Jul 21, 2008
    I have checked the cables, checked the settings, restarted and reconnected the computer and projector. Still cannot find signal.
    Problem Solver:
  • 12 Answers
One problem may be that you must tell the PC to send the signal to the external monitor. Usually, if you hold down the function button and hit the F5 key you will see several options on the screen. (Other laptops use different function keys. Look for the one that shows two tv screens. You want the option which shows the laptop and the external monitor.) To advance between options, you hit the F5 button again and it moves over to the next option.
My computer needs me to lower the resolution on the laptop in order to send the signal to the projector. If you also need to do that, you can do it in Control Panel, Display, and Settings, and lower the resolution on screen number 1.
Doing both of these things should work.
Also, confirm that it is finding signals by hooking it to a DVD or video and see if it finds the signal through one of the other ports.
Posted on Mar 24, 2008
I tried all the troubleshooting I could think of and I spoke with a tech at Dell. It was decided the issue was a hardware problem on the projector not the computer. As a last resort, before I sent the projector to be repaired, I swapped out the cable. I was in shock when the projector found the signal. I cannot figure out why the cable failed but this did solve the problem. It was a cheap and simple fix.
Posted on Aug 28, 2008
Our Dell 2200MP is hooked to a new computer with the Windows WP Professional operating system on it. It projected fine until I tried to play a video off of a CD. The computer monitor screen went "crazy" and the projector lost the signal. I am unable to get a signal now, after rebooting the computer, going to the Display panel and checking things out, etc. The projector still works when I connect it to other computers.
  • judyaschmid Aug 28, 2008
    Sorry, I didn't see that the above entry was going to be put in as a solution. As you can see, it's a problem needing a solution. I guess that I have more than ONE problem. :)
SOURCE:
Projector Dell 2200MP not connecting to laptop inspiron 6000
Hi you need to check the cable to see if it is faulty you can do so by trying another cable or by trying that cable on another computer,you need to check the USB port also,try to connect using another USB port.
Aug 04, 2010 | Dell 2200MP Multimedia Projector
Connect to a computer to project a slide show
laptop connected. projector on and running. blue screen up and reads "searching for signal" has been doing that since both machines were turned on for thirty minutes. what now?
Jun 16, 2010 | Dell 2200MP Multimedia Projector
I have connected the projector to my dell laptop and there is a message "searching for signal" coming up. What do i have to do?
Once the projector is connected to your laptop, and both devices are powered on, press the Fn + F8 keys on your laptop to toggle your screen to the projector.
Oct 11, 2009 | Dell 2200MP Multimedia Projector
I have a new Macbook Pro and am giving a presentation tomorrow using a Dell 2200mp projector. I cannot get it to sync up and the only cable which works as far as I can see is the USB. HELP!!
Macbooks are equipped with a mini-dvi port this is what you will utilize to send a video signal to your projector first thing you need to figure out is what input is on you projector either it is dvi or vga then go to best buy and get a mini dvi to vga adapter it is only for macs let me know how it comes out
Jan 27, 2009 | Computers & Internet
Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Jul 28, 2008 | Dell 2200MP Multimedia Projector
Power Supply Unit of Dell 2200mp
first look at the dell site.
Then try to get your country dealer .
Before that contact your dealier
Jul 23, 2008 | Dell 2200MP Multimedia Projector
Dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Searching for signal
There is an "Auto search for signal" setting on the projector settings menu. This may be turned off.
Oct 04, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP Multimedia Projector Logo
3,222 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
