Question about Samsung CLX 3160fn All-In-One Printer
Light lines down middle when printing black
This does not occur with any other color printing. One line is about 1/4" in teh exact middle with a smaller stripe down each side. Have cleaned many times, have bought a new toner cart. have also shaken toner cartridge. Cannot seem to get rid of streak.
Norm
  • 523 Answers
Try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
Posted on Apr 24, 2009
Black line in the middle of the page
Check OPC drum on toner maybe is a green color of drum and error maybe is the laser is printing and no light go from laser to upc drum is maybe dirty laser light and drum clean printer and write how do it goes thanks..
Nov 07, 2013 | Samsung CLP-325W Wireless Laser Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
Problem making copies (not print from my computer)
Does the line show up when you copie from the bed of the scanner or from when you send it through the auto feeder or both? Check the glass for any small mark and remove it if you find one and try again. Its more then likely a mark on teh glass somewhere.
Jun 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
My copier prints fine than suddenly a line will print very lightly then the next line is fine
It will be extremely difficult to provide any solid trouble shooting tips not knowing the type of copier (Manufacture’s model number) or the type of technology that your copier is using (Laser vs InkJet).
I can offer some common logical trouble shooting which I hope will assist you in your fault isolation process.
1. Is there ‘pattern’ to the ‘light line’ symptom?
  • Same location on each page then it occurs?
  • Is the number of pages between occurrences the same?
  • Occurs on text only; Occurs with graphic material
  • Is it a ‘full’ line or part of the line?
2. Does this occur with both Black/White and Color print outs.
  • Some software applications will use the color cartridge to print the color Black as oppose to using the Black ink cartridge.
3. Does this occur when using a specific application?
4. Are you able to determine a MTBE (Mean Time Between Events)?
  • If so, then you can reproduce the symptom and attempt to isolate some of the variables I have listed above.
Again, we need to know the make and model of the unit in question to be more specific.
I hope this helps,
RojoSho
Jan 07, 2010 | Office Equipment & Supplies
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Bad printing
just for info my printer wasn't printing much of anything black and color. If you hold down the middle button till the light on the top blinks twice it will give you a color test page. it should give you a grid to the right and to the left it should have the letter H and two blocks. If it doesn't you hit the middle button until the light blinks once and that is the cleaning. I have had to do almost 25 cleanings just today to finally get some results. Hope this helps you.
Dec 04, 2007 | Canon PIXMA iP2000 InkJet Printer
Samsung CLX 3160fn All-In-One Printer Logo
240 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
