Question about Gateway FPD1960 19" Flat Panel LCD Monitor
The screen says no signal then goes black - Gateway FPD1960 19" Flat Panel LCD Monitor
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
Jun 06, 2011 | Dell Dimension 2400 PC Desktop
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
Hp 2009m screen goes black - no signal
change frequency setting to 60hz from the option of graphic setting using another monitor then agin connect your problematic monitor.
step1.open properties on desktop using right mouse click.
step 2.goto last tab (setting)
step3.goto advance optinion
step 4.goto third tab(monitor)
and there is option of frequency change it to 60hz save it and press enter.
now shutdown computer then connect your screen goes monitor check it.hope it works.
when screen black its mean the range of signal frequency higher then compatible frequency.
Aug 01, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Black screen on monitor
chack your ram
your display cord may be damaged or loose chack it
Feb 23, 2009 | Computers & Internet
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
