When i burn a dvd it says at the end failed 2 burn can not create dvd
    Scholar:
  • 154 Answers
I solved it by dropping Nero. I used to love it, but when it can't cut it any longer, it's time to move on. Now I use DiscJuggler and it has performed very well on several burns.
Posted on Apr 24, 2009
I have Sony play station 2 model SCPH 75004 which is failing to play PS1 DVD and CDs. I hear it requires a mod chip. Where can I get the mod chip and how is it installed to the PS2.
ruben, the PS1 is the only system created with the capability of adding a mod chip. When they first came out, the PS1Generation 1(PSX)could play burned games and DVD's. Sony discovered that it created an issue with the excessive wear of the cd drive, so they recalled the system. Then they re-released it and it couldn't play DVD's anymore. The PS2 could already play DVD so it has no mod chip function.
Dec 29, 2014 | Sony PlayStation 2
Tip
How to create a Windows 7 system repair disc
1) Click Start → All ProgramsMaintenanceCreate a System Repair Disc
2) Insert (CD/DVD) into the drive and press create disc
3) Wait until the burning process is done.
now accumulate the System Repair Disc safe back it will be bare back Windows 7 fails to boot.
on Aug 30, 2010 | Computers & Internet
While I was trying to burn a back up recovery disk for my emachine's windows vista, emachine didn't come with one, but a program on it to install one. I was told to use 10 writeable cd's or 2 dvds, i...
The problem here is that when disk burners stopped being $400 each, the quality went way down. What's likely happening is that your burner is sucumbing to an alignment or heat-related issue. My gut feeling tells me that you should do the burn, then wait about an hour (maybe two) and do the second disk so the electronics and mechanical parts have time to cool off.
[rant] The real issue in your case is that eMachine's recovery system is an after-thought. Any well thought-out system would let you select which disk to burn or give you the option to make ISOs so you could burn them on another machine. More importantly, they should just let you do this to an 8GB USB stick and call it a day. I would avoid machine that can't be bothered to give you an easy way to recover their machines, then give you the responsibility of creating the recovery media on sub-par hardware. [/rant]
Anyway, let me know how it works out.
Feb 28, 2011 | Computers & Internet
Issue with acer aspire X3812,cannot burn dvd
Reinstall the Nero Software or any dvd writer software. first unistall the previous installed one.
Nov 26, 2009 | Computers & Internet
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Mar 24, 2008 | Computers & Internet
Burning dvd image using Roxio disc copier
burning dvd images using roxio really does wonders. however, when you trying burning it to your physical dvdrom, it fails. this may be due to firmware bugs or needs some fixes. have it updated to the lastest firmware update and regularly clean your vdvroms lens with a cleaning kit.
so how is it now?
Jan 28, 2008 | Optorite (DD1203) DVD±RW Burner
I have purchased roxio easy cd and dvd burning software
FIRST TRY USING MEMOREX DVD-R DVD MEDIA & BURN AT A SLOWER SPEED
Jan 23, 2008 | Roxio Easy CD & DVD Creator 6...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
