Frigidaire ATFB6700FS0 Washer Won't Start E41 error
RixsFixes
  • 2200 Answers
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
** This took me about 30 minutes from start to finish.
Posted on Aug 12, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Frigidaire ATF6000FS1 Error Message E41. I set up
Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
Posted on Apr 08, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have an Frigidaire Affinity
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 01, 2011
Jahn27
  • 1554 Answers
SOURCE: Frigidaire Affinity washer (LAFW3511KW0) with
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Posted on Aug 21, 2011
Error code E 23 How do I test drain pump? The unit rolls to the left then shuts off with a beep beep beep.
[PDF]Error Code E23 Frigidaire Washing Machine - WordPress.com
https://grednandwestsign.files.wordpress.com/.../error-code-e23-frigidair...
E23 Drain pump relay on control board failed or wire off pump. E24 Drain pump relay If your. Frigidaire Washing Machine Error Code is not listed here, check Then the code E41 appeared and. I could do nothing else with the washer. The error .
Oct 23, 2015 | Frigidaire Washing Machines
What is code E41 on a Frigidaire Affinity ATF800FS. THE DOOR IS LOCK BUT THE DOOR LOCK INDICATOR WONT LIGHT UP & THE WASHER WONT SPIN
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Aug 03, 2015 | Frigidaire Washing Machines
I have an error code E41 on my Frigidaire ATF7000eso front load washer. How do I test to find the bad part
Good Morning friend, that's a great question!
I see that your Frigidaire washer, ATF7000ES0, is displaying an error code of "E41" and you would like assistance in troubleshooting that code. An "E41" typically stands for your main control board thinks the door switch is open. This could be a possible problem with your door switch assembly or main control board. I would recommend performing a reset just in case there is a miscommunication within the board and you can do that by disconnecting power from your washer for roughly ten minutes. If you restore power and continue to see an "E41" I would look over the door switch to make sure it is not damaged. If any electrical components need to be replaced I would suggest having a professional technician out to properly disassemble your washer. This will help you to avoid any future issues. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
Error message e41
Hello Friend, thank you for your inquiry!
If you are receiving an error code E41 on your Frigidaire front load washer, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging your washer or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your washer's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Hope this helps! - Z
Jul 07, 2014 | Frigidaire GLTF2070DS Front Load Washer
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Dr is flashing. The error code is E41. How do I correct the error code. Door is closed. Started flashing in the middle of cycle.
Hello, welcome to FixYa. I understand you have a Frigidaire washer with an error code E41, correct ? Can you reply and include the complete model number ? This will let me speak specifically about your washer instead of generalizing...which can be fine, but specifics are always better. I'll watch for your reply and go from there. Thank you. Regards, Macmarkus :)
Sep 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000FS1 Error Message E41. I set up the machine, hit the start button, and I only get he PAU note across the screen. The washer will not start up. Ran the Diagnosis and come up with E41. ...
Hello
Apr 08, 2011 | Frigidaire Washing Machines
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
