Question about Toshiba Satellite A65-S1066 Notebook
WiFI atheros card quit working after installing a new hard drive
The WIFI Atheros PA3373u-1mpc Card in my Toshiba Satellite a65 model PSA 60u-o2k05 quit working after installing a new hard drive.
Interchangeable parts
I dont think so as the S1712 uses the AtherosĀ® 802.11 b/g wireless-LAN card and the s2716 uses the IntelĀ® PRO/Wireless 2200BG card. You can call Toshiba TS to verify, but most likely they are not interchangeable as they are different. That doesn't mean that it is 100% a no go as it still might function, but chances are slim. Here are links to the specs for each machine:
http://support.toshiba.com/support/staticContentDetail?contentId=1250461&isFromTOCLink=false
http://support.toshiba.com/support/staticContentDetail?contentId=1262112&isFromTOCLink=false
May 24, 2014 | Toshiba Computers & Internet
Atheros AR500EG wireless Network adapter tired
Well those are actually PCI cards. You can have the wifi card replaced or buy a USB WIFI adapter as that would be cheaper.
Aug 16, 2010 | Toshiba Computers & Internet
Reloaded operating system. Wi-Fi does not work. No Sign of software or drivers
Most laptops WIFI has a switch if its turned off sure you will not have anything show up so make sure this is not the case. Most laptop this is the issue and allot of people bypass this when it comes to my desk and wonder how i got it working in secounds. So look for a switch.
thanks and I hope this helps.
Dec 13, 2009 | Toshiba Satellite A65-S1762 Notebook
My Atheros wifi card doesnt even appear in my device manager
go to www.toshiba.com and go to support put in model of computer and they will have it there
Jun 06, 2009 | Toshiba Satellite A45-S151 Notebook
Lan and wireless driver for toshiba a135-s2246
Unfortunately, the Toshiba Satelite A135-S2246 was never designed to run XP, only Vista. Which is why you can't find any drivers for XP. The nearest you can get is to find a laptop running XP SP2 that is using the same LAN (ethernet controller) and WLAN (wireless ethernet controller), and see if they will work.
Here are the drivers I found for XP (please check which one's you are trying to install):
Atheros WiFi card driver:
http://www.wireless-driver.com/download/atheros/2007-7-23/Atheros-ar5bxb6-AR5424-mini-PCI-E-Wireless-Card-Driver-Download.htm
Intel WiFi card driver:
http://downloadcenter.intel.com/default.aspx
You will need to search for the card that you have.
LAN (ethernet controller):
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
You can pick third or fourth from top depending on your preference.
Please remember that Toshiba, Microsoft, Atheros, Realtek, Intel and especially myself accept no responsibilty for what may, or may not happen when installing drivers not specifically designed for your system. All that said, I hope it works for you.
Dec 05, 2008 | Toshiba Satellite A135-S2246 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Wifi on 5720Z
I solved my problem, turns out my laptop has the Atheros card, not the suggested Intel card. I found a driver for Atheros from a different Acer Aspire model, and it seems to work fine.
Mar 14, 2008 | Computers & Internet
Toshiba Satellite A65-S1066 Notebook Logo
659 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
