Question about Thermador C302U Electric Double Oven
Thermador c302us,flow switch needs replacing,error code f34, cannot find part #
5 Suggested Answers
  • 3 Answers
SOURCE: troubleshooting thermador
call thermador service center 800 735 4328
Posted on Mar 10, 2008
taran_2005
  • 10515 Answers
SOURCE: code f34 for my thermador
According to a Thermador error code book for a single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the control board that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.This could also be a result of fan may be too dirty to operate correctly. Try to clean the oven. If you had this error after electrical surge or outage recently, then turn off the dedicated circuit @ circuit breaker box for about 1 Hour and hopefully it would resolve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 24, 2010
SOURCE: F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Posted on Feb 18, 2011
  • 195 Answers
SOURCE: I have a Thermador C301-UW
F34 ( Upper oven cooling fan air switch not detected ) Replace air switch,cooling ...
on door
Posted on Dec 02, 2011
How do I fix an F34 error code on a single Thermador wall oven?
If the fan is blowing, then likely a sail switch problem. If switch ok, we see control board failures that cause this also. If need be, we can rebuild the boards for you. See
Limited supply of refrigerator boards for sale Used in Whirlpool...
Sep 15, 2015 | Thermador Ovens
F34 error
coolingfan/air flow issue on the upper oven
Feb 14, 2014 | Thermador SECD302BPSS Electric Double Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
What does F34 mean as an error message?
Hello, welcome to FixYa.
The "F34" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the upper oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F34 error, it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
example:
( F34 can also be initiated by a failed "K6" relay on the control board, but that is less likely )
It can be accessed by way of removing the grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Thank you for choosing FixYa today and good luck, please take a moment to rate the info provided here for you.
Regards,
Macmarkus :)
Sep 15, 2011 | Thermador SC302T Electric Double Oven
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
Mar 10, 2008 | Thermador C301U Electric Single Oven
Thermador C302U Electric Double Oven Logo
54 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
