Question about Alcatel Cell Phones
Headphone jack not working - Alcatel Cell Phones
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
it shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Jan 11, 2013 | Computers & Internet
Headphone jack requires bending the headphone jack to a side to get stereo. this is the coby mp725 16 gig love the unit. got it as a gift. had to send my first unit in due to headphone jack not working....
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
Jun 30, 2011 | Coby MP725Digital Media Player
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Dec 05, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Button/Jack
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
Cell Phones Logo
22 people viewed this question
Top Alcatel Cell Phones Experts
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Dakshinamurthy...
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
