Question about Brother MFC-260C All-In-One InkJet Printer
Need to set up phone/fax instead of just fax
I have plugged phone into phone line with fax line. When I ring the number it rings both phone and fax. I pick up the phone and the screen says press Tel/R which I have done but it still does not appear to be working. Is there something else I should do?
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Posted on Apr 24, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
Cannot send fax but can receive fax.
You do not give enough information. What happens when you try to receive? Does it ring? Is there any message displayed?
You will have to look through the options in the unit to find the receive settings in the menu. Make sure it's actually set up to receive. Usually there are receive (RX) options such as: manual, fax/tel, fax only, number of rings, distinctive ring and others.
In most cases if the machine is set to manual, you will have to press a button to receive a fax. It may be just the "hook" button, or a start button. Check your owners manual to see which button. In Fax/Tel mode the machine will assume you are using a telephone on the same line. You will have to set the unit to answer after the phone rings a specific number of times(four, for example). After four rings, if you have not picked up the receiver the machine will take the like and receive a fax. If you set it to Fax Only you can set it to answer on any number of rings, but it's best to just set it to one. In this mode the machine assumes it has a dedicated line.
If you have distinctive rings for various people in your home or business then you will have to consult your manual to see how to deal with the different rings.
One last note. Make sure your phone line is plugged into the correct port on the machine. I get a ton of calls at work from people who have the phone line plugged into the extension port, and the phone plugged into the line port.
If none of this helps, you will need someone to look at your fax machine. If you call HP, have your credit card ready.....
Sep 23, 2010 | HP Photosmart 2610 All-In-One InkJet...
Our IntelliFax 4750e will not receive faxes. The line has a dial tone, and rings when called. It is set to "fax" and not "fax/tele." Suggestions?
There are a few possibilities. 1) The phone cord coming from the wall is plugged into the phone port on the fax instead of the Line port. It should be on the line port.
2) The fax have been set for distinctive ring. This causes the fax to ignore the normal incoming ring tone and is instead waiting for the distinctive ring from the phone co.
3) The modem in the fax has gone bad. If you have had any power failures or electrical storms/problems this is a possible cause.
Some models will also not answer if the machine is out of toner or paper.
Oct 21, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Hpc6180 does not receivefaxes with distinctive ring
If you have an answering machine you should set it 2 rings lower than the all in one printer.
Settings :
Distinctive rings : 3 rings
ECM : off
Fax speed : medium
auto answer : on
- after checking this settings try calling your fax number.. if there is a static then the phone company should fix the problem.
- if you have the same phone number and fax number make sure no one is using the phone
- if there is no static on the line try resetting the printer.
* Unplug the power cord of the printer at the back of it while it is still on. After 30 seconds plug the power cord back in but you need to press and hold # and # at the same time. Do not release the two buttons until the printer would say "reset"
* check the settings of the all in one printer again
* try testing the fax machine. if this is not solve. instead of pressing # and 3 try using # and 6 but with the same process.
- the difference between # and 3 and # and 6 is this
# and 3 > partial reset
# and 6 > semi-full nvram reset
- if ever # and 6 did not solve the problem then the printer is defective. IF it is brand new printer try returning it to the retailer because if you are going to call HP they are going to replace the printer with a refurbished one.
Mar 31, 2009 | HP Photosmart C6180 All-In-One InkJet...
Need to know how to change the number of rings on the fax.
Press
Funcion
7
monitor key slowly 4 times
set
clear 2 times
use number pad to set number or rings 0-15
set
Unplug power cord, plug back in.
Nov 26, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
X5495
Make sure the "Auto Answer " button is On
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
May 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Fax phone hookup
Use an identa call box. You set the distinctive ring pattern (1-2-3) and the box will route the call through depending on what number it is. I have two numbers on one line. I have a tee adapter on the phone plug with two phone cables coming out. Each phone cable one plugs into a small distinctive ring box. I set one box switch to 1, and the second box to 2. If the first phone# rings box 1 allows the signal through to the phone. If the fax line rings the phone won't ring, but the second box will pass connection to fax and vise versa.
I brought mine from Bell Canada phone store. It is called a identa-call box, or distinctive ring switch. Best way to go !
Mar 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Phone line and fax line
If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
Also, you have to enable auto-answer on the fax machine.
Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-260C All-In-One InkJet Printer Logo
280 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
