Question about Furniture
Natuzzi recliner repair
Replaced cable with chair upside down. by accident i closed ottoman ie. foot rest before chair back. now i cant move either
SOURCE: UPSIDE DOWN SCREEN
Sorry, you can't really solve this without sending the thing back to Motorola. Better get insurance next time. I just did. :(
Posted on Jan 08, 2009
hmerchant110
  • 7191 Answers
SOURCE: My acer mini laptop screen is upside down!!!!
It seems you pressed CTRL+ALT+UP arrow key. To turn it back press CTRL+ALT+'DOWN' arrow key.
Posted on Jun 15, 2009
  • 61 Answers
SOURCE: Chair is stuck fully extended foot rest up and
Providing you have power to the chair, this will be a faulty handset or a faulty limit switch inside the actuator assembly.
Posted on Mar 18, 2010
  • 31 Answers
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Posted on Apr 07, 2011
diodeic
  • 1622 Answers
SOURCE: MY CHAIR IS IN THE RECLINING POSITION AND IT
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Instructions
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Why doesn't power button work?
You will have to turn that bulky recliner on its side or even upside down to get access underneath. Inspection may reveal that the real problem is damaged or disconnected wiring but it may turn out that the switch is defective and will have to be replaced.
Sep 06, 2015 | Furniture
Fix the foot rest
Please state what part isn't working, does it open or won't it close or is it crooked? Send a picture if possible
Mar 02, 2015 | Furniture
Nina power recliner chair stuck open
Look where the control button is it should be a little space to where you can stick a needle or nail in that the reset button I want you reset it then you should be able to get to a recliner to go back down
Apr 16, 2014 | Furniture Nina Fabric Sectional Sofa,...
Lazyboy recliner foot rest will not stay up!
Check the spring that holds the foot rest closed or open. Flip the chair over and take a look.
Mar 30, 2014 | Furniture
Lafer spring
I have Lafer Kiri chair and spring for foot rest broke
i found replacement spring at Lowes
It is Hillman replacement spring 2 per pkg
Bar code 08236 80104
Works great
Nov 30, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
How can I get the foot rest to close without having to push it back forcefully with my feet?
the model your showing comes with a separate foot stool . you sure you have the same model
Sep 30, 2013 | Fjords 775 Bergen Recliner with Ottoman...
What exactly is a recliner? How is it different from other chairs?
A recliner is a versatile flexible chair that more comfortable than any other chairs.
They are made up of fabric or leather and can be used for both sleeping and sitting.
You can get these recliners from Oversized Recliner, the best pieces available here are:
a. RECLINER GENIUS 360 DEGREE SWIVEL MASSAGE RECLINER
b. PULASKI BIRCH HILL
c. MONARCH SPECIALTIES IVORY BONDED LEATHER RECLINER
d. PULASKI HARMONY SWIVEL GLIDER
e. DIVANO ROMA BONDED LEATHER ROCKER
Aug 09, 2012 | Furniture
How to remove swivel base from lazy boy recliner
This individual wants to remove the base from a recliner, not a tv. Take the back off the chair. Turn it upside down and remove four bolts, two front, two back that bolt the base to the chair on arms. Contact lazy boy first. You can get a new base from them that is stationary and put it in place of the swivel. I have same problem. Swivel is constantly turning and drives me crazy.
Jul 04, 2012 | Televison & Video
Do I need an ottoman with my accent chair?
Ottomans are by no means a requirement with accentchairs. They do complement each otherbut it is totally acceptable to have one without the other.
May 29, 2012 | Furniture
Furniture Logo
50 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
