Question about Sharp Televison & Video
Haw to instal ''TV Listen Ear'' ( wireless earphone )
The ports required on back of tv set are being use for VCR/DVD I . Bought Y-adapters but that's not solution . Also this device have FM radio
ttech
  • 139 Answers
SOURCE: connecting VCR/DVD combo
Put the Tv on Channel 3
Posted on Jul 19, 2007
simplemitch
  • 752 Answers
SOURCE: connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Posted on Sep 20, 2007
  • 729 Answers
SOURCE: portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Posted on Nov 02, 2007
SOURCE: no sound on TV
in that such problem the best solution is to buy another new. . . .
Posted on Nov 26, 2007
  • 58 Answers
SOURCE: wire up tv dvd vcr and freeview
hello
connect your sound output from the rear of the TV to your surrond sound system input.
and all should be well.
Thanks Guy9
Posted on Jun 26, 2008
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
Speaker is off
Most of these combo units do not have a speaker ON or OFF setting but look anyway.
If the set has a earphone jack that may be the problem--see if works with earphone plugged in.
The socket the jack goes into can get flaky as when jack is inserted it turns the sound OFF.
Also put your ear right to the speaker to see if anything at all is heard--the speaker could be bad--but check the above first.
SD TECH
May 27, 2012 | JVC TV-13142 13 in. TV/VCR Combo
How can I listen to audio from Techwood TV/DVD player through home stereo? I have connected a red&white stereo lead & selected aux on my stereo, but sound still just comes out from the TV. Any help is
Make sure that you are using the Audio Out ports (not one of the audio in). Next go into the menu. Select the Audio setup option and see if there is a line for enabling the external speakers. (Often this corresponds to turning off the internal speakers but not always.)
I hope this helps. I'm not familiar with the specs of Techwood TV models. Some TVs only have an headphone/earphone (3.5 mm) jack as their audio out. In that case, you'll need an adapter to convert the RCA audio to the headphone jack.
Dec 09, 2011 | Televison & Video
We have a philips 42" HD TV. We havde a blue ray
theres extra speakers computer speakers you can hook up to port for louder sound.
Feb 17, 2011 | Philips GOGEAR SA6045 MP3 Player
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Coaxial cord won't fit on VCR/DVD
Are you sure that the port that is unthreaded is actually coaxial. I've never seen an unthreaded coaxial port, just unthreaded push on connectors.
What color do you see on the center ring on the connection of the vcr?
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Audio output jack is small; need adapter.
You can buy an adaptor (Large to Small) at any good Electrical store.
Take the jacks with you so they are sure what you require.
The adaptors are not very expensive at all.
Best wishes.
Mar 03, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Televison & Video Logo
123 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
