Question about Samsung PN42C450B1DXZA 42-inch Class Television 720p Plasma HDTV
Won't turn on, blinking light - Samsung PN42C450B1DXZA 42-inch Class Television 720p Plasma HDTV
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
Won't turn on or charge controler
Look at the blinking light count the number of times it blinks and go to google type in ps3 light blinking error code
Apr 13, 2013 | Computers & Internet
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
My plasma tv won't turn on only the light
Blinking light usually is a error code if blinks a certain number of blinks and the place to begin is to look for a bad fuse or bad puffed up caps inside on the power supply board--place to begin.........
Apr 16, 2012 | JVC Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Samsung PN42C450B1DXZA 42-inch Class Television 720p Plasma HDTV Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
