Question about Whirlpool WTW8800YW Top Load Washers
Whirlpool cabrio wtw8800ywo. When water is turned on half way it shoots out the detergent and bleach dispensers causing it to leak out the back . Any ideas?
  • 1314 Answers
SOURCE: Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Posted on Jan 22, 2008
jsrock516
  • 5911 Answers
SOURCE: Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Posted on Sep 03, 2008
robocop
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
mgprice
  • 744 Answers
SOURCE: whirlpool washer overflows at detergent dispenser
Hello, I worked on a problem like this a few days ago. Your problem is going to be a blockage in the inlet to the drum. To fix this problem find the inlet pipe normally located above the door behid a flap of rubber..push your fingers up there to see if you can feel a blockage..If not your going to have to remove the lid of the machine to access the pipe that leads from the detergent drawer to the tub. Look at the rear top of the machine..You will see three screws....remove them and push back and lift the top panel (lid) now you should be able to access the pipe. Pull the pipe off and clean it out, i suspect you will find a sock blocking the pipe :) If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Posted on Sep 04, 2009
Testimonial: "You know what? Your advice was down to a tee. Thank you so much and my wife is happy too. Thanks john"
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Whirlpool Cabrio Platinum is over filling the detergent, bleach and fabric softener dispensers, with great pressure.
sounds like you have a bad water valve on the washer,go to the searspartsdirect.com ,put in your model number and look up the valve.next time send the model number for anything you're having a problem with
Sep 14, 2017 | Whirlpool Wtw8800yw Cabrio Series 4.6 cu....
Cabrio wtw7600xw2 when water enters the bleach or softner dispensers it runs over and leaks on floor. I've cleaned the outlets their clear. Seems too much water comes in to dispenser areas.
If the lines to the drum are clear and draining properly then you will need to replace the water inlet valve since it is allowing to much water to pass through to the dispenser. Here is that part to order. Whirlpool W10326913 Valve AppliancePartsPros com
Mar 03, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Cabrio washer model #WTW7340XWO. I have had 4 shirts ruined with bleached out spots all over them after washing in this machine. We use NO bleach in the detergent. What is wrong?
Hi
It seems that it needs cleaning... you can run your washer with nothing inside it at its hottest temperature setting with 2 cup of vinegar inside the unit. After this clean the drain pump assembly completely, also clean the drain hose and drain pump filter, the spots should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
May 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
After cycle, water is in the softener and bleach
Water floods the dispenser compartments at the start of the cycle to dilute/dissolve the softener, bleach, and detergent. The reason why water is in the compartment after the cycle is that, the detergent, the softener, and/or the bleach does not flow into the tub properly. It's either the dispenser assembly is clogged or excessive amount of detergent, softener or bleach is used. Clean the dispenser assembly and make sure to use no more than two tablespoons of powdered HE detergent or one-and-a-half ounces if liquid HE detergent.
  1. Unscrew the two screws on the back of the top plate then pull it back then upward.
  2. Pull out the dispenser drawer.
  3. Unscrew the two screws then push the dispenser assembly out.
  4. Unscrew the nut at the lower part of the dispenser.
  5. Remove the four connectors from the valves.
  6. Unscrew the two screws from the back of the cabinet.
  7. Reinstall the dispenser assembly in reverse order.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
Dont' know where to add bleach alternative
yes clorox 2 or "dry type" bleach should be put in with the detergent. only liquid bleach will go into the bleach dispenser.
also be sure to use soap that is "HE" type or you will get too many suds and a washer that will smell from not rinsing out.
Mar 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Automatic bleach dispenser
Using too much detergent could cause a baring effect that looks like it has been bleached.
Aug 20, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW8800YW Top Load Washers Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
