Wall panel heater instructions
Lcd3112za
I need an instruction manual for a comfy air wall heater
how do you ste up the comryfair slimline panel wall heater
Jan 08, 2012 | Heating & Cooling
I am looking for an instruction manual for the Dimplex OFC2411TIF Oil Heater
Carly, the owners manual for the model number you listed is not available online. However, if you call Dimplex USA, Technical Service 888-346-7539, they can help you.
Apr 06, 2011 | Dimplex EF12 Electric Wall Mounted Panel...
I have no instructions for re-lighting my furnace's pilot light. Can you help?
Instructions for lighting the pilot can be found on page 10 of this Installation Manual.
Here is link on How to Light the Pilot on a Water Heater. I realize this is not a water heater you are working on, but the setup is very similiar the link has a couple of videos that you might find helpful. :-)
Apr 23, 2010 | Williams 3003622 Ceramic Wall Mounted...
I am looking to install a 4000W wall heater. The wall facing is wood panel. Are their any issues to be concerned with? Please email me at mp4569@optonline.net. Many Thanks
Read the instruction manual that ships with the unit for clearences from combustionalbles. Usually the engineers design the unit to be mounted with a half inch gap around the internal frame but the outer cover may touch the surrounding paneling. it is best to check the installation guide. The unit return or suppy air may not be blocked or impeaded in any way.
Nov 24, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
I'm looking to install the Fahenheat 4000W wall
Hi there, yes you will be OK. Check the installation instructions also. The way these are made, the heat exchanger/elements are away from the wall, a barrier in between the heater and wall to keep the wall what ever it is made of, cool. The installation instructions should tell you this anyway. Best of Luck,
Shastalaker7
Nov 23, 2009 | Heating & Cooling
How to convert the DynoGlo from propane to natural gas?
ther should be instructions in manual. if not go to manufactures website and get number to call or email them
Nov 17, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
FFh Series FFH1614
http://www.marleymeh.com/develop/prod_pdf/instructs/5200-2638-000.pdf
Jun 14, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Installation of Fahrenheat wall heater
Jan 20, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
