Canon ir 2018 copier load correct paper - Office Equipment & Supplies
  • 23 Answers
SOURCE: my canon IR 2018 copier is giving me system error
This is a problem with the fuser unit, this is the section that heats up. Once the code comes up you will need a service tech to come out to check your copier. The code can only be reset by entering the service mode. If your lucky and all looks well in there it may just need to be reset with no parts to be replaced.
Posted on May 17, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 2018
If you have blank copies and prints, and the service man cleand laser, that means that laser unit isnt correctly in or laser shutter doesnt move.
Call him back and claim warranty
Posted on Jun 02, 2010
  • 51 Answers
SOURCE: My canon ir 2018 is asking me to load correct
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Posted on Oct 05, 2010
  • 452 Answers
SOURCE: My canon IR 2018 copier
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Posted on Oct 20, 2010
babaprithi
  • 372 Answers
SOURCE: canon ir 2018 ask system
press * 28* to got service mode. goto clear option and then press clear all machine will restart to initial
Posted on Jun 26, 2011
Canon ir 2018, my problem is after five five, six paper print then paper jam problem from pick up unit
Try cleaning the paper pickup roller, see if that helps.
If it is better, but still not perfect, fit in a new one.
Jul 31, 2015 | Canon Office Equipment & Supplies
Canon ir 2420L loud correct size paper how to loud paper
Dear
Pl. check the setting of the copier to the paper loaded(size and orientation), the tray selector switch,paper drive rollers/guide.
thanks
Jan 06, 2015 | Canon Office Equipment & Supplies
Canon IR 2018 Drivers
You can either write to them for assistance or give them a call - they don't bite.
Aug 28, 2017 | Office Equipment & Supplies
I av a problem wit my canon copier ir 2018 .it is having a display red light flashing indicating out of toner while toner is there.wat is the solution of this problem?
TRY SHAKING THE TONER AROUND ----- COULD ALSO NEED A NEW TONER SENSOR
ARE YOU USING THE REAL CANON TONER ? WILL NOT SENSE CORRECT WITH OTHER OFF BRAND TONER .........
Jun 29, 2011 | Canon iR 2016i Black and White Copier
I tried to copy with my canon ir 2018 and my canon copy a half of the contents,and tell me load correct paper
I believe you don't have the paper size slide on the front of the paper cassette correct. Look at the slide carefully because it also has the paper direction picture along with the size.
Jun 14, 2011 | Office Equipment & Supplies
My canon IR 2018 copier is giving me system error 007
hi;
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Dec 14, 2009 | Canon imageRUNNER 2018 Copier
18 people viewed this question
jasbo
jasbo
