Question about Craftsman Rear Mount Tiller
Can't find filler plug on transmission
I have a craftsman rear tine tiller w/a 5hp briggs & stratton. Model # 917.299752. I am trying to re-condition it back to an operable state, but without a user's guide I am lost as to where to insert gear oil into transmission (filler plug). Please help
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Posted on May 03, 2009
I have a PowerPro 5 hp rear tine tiller with a 5hp B&S engine mdl 352-02. Where can I get some schematics of the engine?
First you need the model and type from Briggs then you can look at several online source for engine's ipl,
Here is some guides on finding your engine's numbers.
Briggs Stratton Model Number Locator
hey also have the ipl and parts for you to order from or you can support your local dealer.
May 10, 2015 | Garden
I need a owners manual that gives the belt assembly for a Briggs & Stratton 5hp choremaster dub-l-tines.
Your best bet is to call your local small engine or outdoor power equipment dealer with a model number. The parts dealers can look up your belt in no time flat. 25330869-xrysbksmd4oe40lchygmaasz-4-0.jpg
Dec 20, 2014 | Garden
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 | Garden
Trying to find a maintenance manual (exploded view of transmission) for a craftman rear tine tiller (may have been made in Canada), with 5hp Brigs & statton (1985 from motor serial). The tiller serial...
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.Try 917. as the first part of model #.
RGS
Mar 17, 2011 | Craftsman Garden
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
May 29, 2010 | Craftsman Garden
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Craftsman Rear Mount Tiller Logo
289 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
