Maytag Dependable care Heavy Duty Fabri-matic Super Capacity 7 cycle will not balance out during spin cycle.
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
robocop
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE Washer , which is a 9 cycle, 3 spd
You need to check the lid switch for continuity. A bad lid switch will prevent this machine from agitating or spinning.
Posted on Oct 05, 2009
  • 278 Answers
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Posted on Oct 16, 2009
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Won't spin or agitate
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
