Question about Vtech Lands Phones
How do i set my pin for remote - Vtech Lands Phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Enter the model of your VTech system into the search box at http://www.vtechphones.com/support/general/manuals to download the manual.
Posted on Jul 08, 2014
Where can I get a PIN for remote control?
PIN for the remote? are you mean the set-up codes?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 05, 2015 | Televison & Video
Tip
Forgot your pin, no problem
If you forget your pin number, there is a way to reset it without much trouble.
In the Menu , go to settings.
Under Settings, go to Reset All.
It will ask you for your pin. Just enter 0000 and continue.
If you've misplaced your remote you can do all of this (almost) with the buttons on the side of the TV, but you will need a universal remote to enter the 0000.
It took me 45 seconds to do all of this.
on Feb 02, 2010 | Televison & Video
Lost pin for samsung TV LE19R8
Hello
If you did forget the PIN of Samsung LE19R8, do the following.
Press the remote control button in the following sequence, which resets the PIN to [0-0-0-0]:
POWER(Off), MUTE,8,2,4, POWER(On).
This process will set your PIN to initial settings, and you have to set it to new passcode. OK.
Apr 13, 2011 | Samsung TXK2754 27" TV
How do I set a PIN to retrieve messages?
Remote code
A remote code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. Store any 2-digit number (00–99). The default setting is “11”.
1 Press {MENU}.
2 Scroll to “Initial setting” by pressing {V} or {^}, then press {>}.
3 Scroll to “Set answering” by pressing {V} or {^}, then press {>}.
4 Scroll to “Remote code” by pressing {V} or {^}, then press {>}.
5 Select the desired remote code by entering a 2-digit number (00–99).
6 Press {Save}, then press {OFF}.
Note:
To confirm the remote code, repeat steps 1 to 4. Press {OFF} when finished.
Feb 10, 2009 | Panasonic KX-TG2431 Cordless Phone
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control settings
There's two options, depending on the brand of remote. The most common is that the reciever located in the fan ceiling canopy has the same switches. Check how they are set and match it on the remote. The other option is that the reciever matches the frequency of whatever the remote is set to. To set this you have to turn off the circuit, wait a minute or so, turn it back on. Then on the remote, hold down the "stop" button for a few seconds. It should be set. I'd check the receiver first though. I should mention also, that when they come from the factory, the switches are usually all in the OFF position (or possibly all in the ON position). Unless they were changed on installation (which may be the case if you have more than one remote controlled fan) they are probably set that way. Try that first.
Dec 24, 2008 | Fantasia Viper (110927) Ceiling
How to set up the security code to check my messages when not at home.
Allright,
Well for starters if you need a manual for that you can get it here:
http://www.uniden.com/pdf/CXAI5198om.pdf
The first thing you need to do is set up a security pin for the remote access, see pg 42 of the manual
Then see pg 49 for remote instructions.
Basically set up the pin, call your house and during the answering machine greeting press 0 and the pin you just set up. Follow the voice prompts to listen or delete messages.
Good Luck
Hope tis helps
Jun 30, 2008 | Uniden Lands Phones
Lost remote to ceiling fan
Go to any hardware store and buy a replacement kit. You'll have to take down the fan (turn off the power first) and remove the black remote box from inside the cup covering all the wiring. Replace that with the new black box that came with the new remote. Make sure that the remote control and black box pins are set the same and reinstall your fan. Total time, probably 30-45 minutes plus a trip to the hardware store. Level of difficulty, moderately easy. Cost, probably $15 min to $40 max. Anything above $40 and you may as well replace the fan altogether. Note: Before you remove the original black box, check the pin settings and set the new hand remote to those settings. Turn on the power and try to turn on the light with the remote control (don't turn the fan on unless you totally reinstalled it) - if it works, you may not need to replace the black box.
Apr 18, 2008 | Heating & Cooling
Need pin code
I would get a generic remote and program it for your set. If you mean that you don't know the security pin which you created for the set you could have big problems. If you are talking about the factory pin, that is usually in the operation manual or you can contact the company. Generally the factory pins are simple like 1,2,3,4.
Jun 19, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Lands Phones Logo
14 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
