Question about Compaq MP1600 Multimedia Projector
Dlp color whel glas
Please i have one mp 1600 dlp chip working ok in black and white but color whel is brocken i dont know how i by in e bay where i by color whel for this projector and where i see some service manual for open this projector please help me if you want maybe some picture of opening thank you for help
  • Anonymous Sep 17, 2008
    not
  • brian Sep 17, 2008
    how do i open mp1400projector
The projector is easy to open. whole side comes off including half silver bit at top you need to search for little rubber dots about 4mm in diameter, pick them out with a knive then undo the screws you will also need to remove one of the hex screws that the vga cable screws into. will not hurt to remove both, just use some pliers to loose them. Also remove the bulb door.
Posted on Mar 22, 2008
SOURCE:
White dots like a constellation, each time more... I know it is de DMD Chip but, Why the hell the chip replacement is SO EXPENSIVE??? Anyone knows about a DMD CHIP 8060-6319W for a LG DS420 DLP Projector...
May not be the chip. Look for a haze build up on the optics that the lamp housing contain. The color wheel will get it too. A simple water only...no chemicals will clean it. The chip is so expensive because the surface of the chip is made up of thousands of tiny mirrors. The video signal processor tells the chip what mirror to direct the light to the color wheel and then on to the screen optics to make the picture..
Sep 30, 2013 | LG DS420 DLP Projector
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
Black and white picture and white spots
if it is the color wheel issue, you can replace it, i have this acer X1160 color wheel, if you need please contact me
Jul 11, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
Do I need to add developer at set-up?
yes the 1600 and 2000 dont have it the easiest way to check is take pcu unit out if it feels very light theres no dev in it
Aug 13, 2009 | Ricoh Aficio MP 1600 Black and White...
Screen goes blank after being on for a while
if it goes black but the light is still working the dlp chip is failing this is like a small lcd screen that the light use for the piture to work looks like this http://www.fixyourdlp.com/2012/04/24/the-affordable-solution-to-white-dot-syndrome-on-your-dlp-tv/ hope this help you.
Jan 30, 2018 | Samsung DLP HL-P5663W 56" TV
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Color
heard a crack & black and white picture is ok please check chroma ic & its related parts of chroma portion of that IC
Sep 23, 2007 | Samsung DLP HL-P5663W 56" TV
Compaq MP1600 Multimedia Projector Logo
224 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
