Question about Frigidaire Heating & Cooling
Compressor not coming "on", model LRA257ST2
Compressor on but wont freeze
You might be low on gas in your compressor. If compressor comes o b but doesn't cool chances are gas is too low. Make sure coils are clean and air gets to the back of the unit
Sep 13, 2014 | Grindmaster CTH-3311 Frozen Drink Machine...
Amana AC not working blower will come on but compressor will not any ideas?
compressor may be leaking. and you are losing Freon, Have a HVAC tech come and check compressor for leaks.That is probably why the compressor is not working. Also make sure the filter is not dirty and plugged up, that would overheat the compressor, shutting it down.
Sep 03, 2014 | Heating & Cooling
Electrolux model
Dear Pls set the room temp at 16 deg then check. Might be it get on , if not then it is relay fault in PCB. send me snap of pcb
Oct 14, 2013 | Frigidaire Heating & Cooling
My AC mod#LRA257ST2 will not come on. Was working fine and just went off now it wont start. I have checked the power and it has it. Is there a fuse on the unit that may need to be reset
There are no fuses on such units, have you reset the GFI plug if it has one? Have you tried another plug or outlet? Clean the air filter and any coils or parts you can reach and retry.
Sep 02, 2012 | Frigidaire FAC126P1 wall/window Air...
I want to know the most effecient height as to wall mount my Model LRA257ST2 25,000 BTU air conditioner. Is closer to the ceiling better?
Yes, closer to the ceiling is better. As, hot air rises and cold air falls. Just keep it about a foot off the ceiling.
Apr 06, 2011 | Frigidaire Heating & Cooling
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Clicking noise coming from my fridge, why?
Depending on model number and location of noise I believe with any refrigerator that clicking will come from compressor overload when the compressor tries to start. Certain GE Models that fall into the category of Profile/Artica have motherboards that make the same clicking sounds when they go bad. If coming from compressor then it tells me that the compressor is trying to start. If so and the clicking continues the compressor could be damaged. If you need someone to assist you in repair I will gladly assist you. Sea Breeze
Mar 20, 2010 | GE Refrigerators
Motor runs but compressor won't come on
replace the RTX overload on the compressor body it just unplugs then get a new one and that will fix your problem
Dec 13, 2009 | GE Refrigerators
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
Heating & Cooling Logo
37 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
