Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Keyboard typing by itself.
My logitech keyboard is writing jibrish by itself, I tried everythig but as soon as I connect it, things go insane.
  • 3 Answers
SOURCE: Logitech cordless keyboard types
usually there is a way to install back to factory setting. Ctrl + Alt +suspend macro. Logitech may have this combination not sure what it might be. Look at suspend macro keys or remapping of keyboard fora solution from logitech. Otherwise you may have to take the batteries out and leave them out for a short time then try to reboot to the receiver and see if this works.
Posted on May 12, 2008
SOURCE: Logitech wireless keyboard doesn't respond
I also had a non-responsive keyboard that worked for a couple of days after installing. I purchased the unit over a year ago due to a great price. Since it was most likely out of warrantee and new batteries did not help, I open the unit and found a cracked solder connection on the positive battery terminal. I re-soldered the connection and it now works great.
Posted on Jun 06, 2008
SOURCE: Logitech Keyboard
Press Ctrl+Alt+F12.
The green light on the keyboard starts blinking.
Press the connect button on the wireless sender then on the bottom of the keyboard. Do it twice if necessary.
The keyboard should do it now.
Do not ask me why ...
Posted on Jun 16, 2008
  • 5 Answers
SOURCE: my logitech wireless keyboard won't type. i
go to logitech support, download setpoint software and follow instructions on setting secure connection. i just did it with mine and keyboard got fixed. your symptoms should be that the qwerty keys dont work but the multimedia, clock and function keys are working. the setpoint software will take care of that.
Posted on Jan 05, 2010
SOURCE: replace key on logitech illuminated keyboard
Since this happened to me accidently a few times and I saw this thread, I thought my 25 cents could help others. I like the keyboard and it is troublesome to send it back for repair for a little thing like this. In my case, I was left with the square black key top and a pair of white hinges detached. You should replace the hinges properly in the base board first and after that press the key top gently and uniformly until you hear a couple of clicks. Make sure you are not irritated when you start this job and do not apply extreme force. It needs a little patience and fiddling. Unless you are lucky or an expert, it takes a number of times until you get it.
The two hinges need to be inserted in the metal clips of the base only after they are put together, not individually. Each hinge has two little rods on the narrow side and two little rods on the wider side. The wider side rods face up and will attach to the key top later. By now, you should be sure which rods of the hinges are up, towards you. Next, the hinges have to be attached to each other in the middle, like a foldable beach stool. You observe that one of them has a middle pin on each side, whereas the other has a corresponding cavity in the middle.
At the time you attach the hinges to each other in the middle, it has to be in such a way that the top part of each of them is smooth, that is, the part that will contact the key top. The side of the hinge that contacts the base has a little tongue between the two narrow rods. This tongue should face down in both hinges. You are now ready to place the little beach stool in the keyboard base.
In my case I inserted the hinge with the open part into the right metal clip and next inserted the rectangular opening to the left metal clip of the base. Whichever you do first is easy, but the second one might need a little help with a tiny screwdriver, or a tool with a similar effect. You might need a few attempts.
Now, your little hinges are attached to the board base and are not flat. They actually look like the legs of an open beach stool. Note which side of the key top is correct, it is annoying to go back to the beginning because you put the character upside down. It is time to press the key top gently and uniformly until you hear a couple of clicks. Unless there was serious damage to the board base or the parts we just mentioned, the key should work as smooth as the other keys.
Posted on Jul 14, 2011
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
May 25, 2012 | Dell Inspiron 531s Notebook
Is there a strike over key
Is there no "insert" key? Normally you tap th einsert key and it toggles between insert and over-write (or strike-over) mode. If there is a numeric keypad tape the "0" key on it provided the numeric pad is disabled. Same thing.
Sep 25, 2017 | Logitech 967233 Keyboard
Trying to use overhead projector on laptop with wireless keyboard
Should be the same thing. Laptop is just sending commands to laptop which is already connected to the projector.
Otherwise try contacting Logitech directly here: http://support.logitech.com/contact
Feb 07, 2018 | Logitech Cordless Desktop MX3200 Keyboard...
Logitech keyboard/mouse interference with broadband
drop thye receiver into the drawer or to the floor away from the modem.
Sep 14, 2009 | Logitech Cordless Mouse
Logitech keyboard 3 months old,wireless, cannot get anything to write, pressed connect buttons under keyboard and on moluse, please help
in logitech we get three thing 1/ mouse2/ keybowd 3/ usb senser if your ke bord is not working look battery of key oard and mouse 2/ your use port is suppor ting or not look on devious manager . if not able to contact . your goods is damage.
Jul 13, 2009 | Logitech 967437-0403 Keyboard
How to make logitech keyboard & mouse work??
Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Mx3200 keyboard
I had exactly the same problem - ie Logitech MX3000 keyboard with remote mouse and only the "F mode" key and few others seemed to work around the top of the keyboard, but I don't think I had the SetPoint software. So I found it and downloaded it (www.logitech.com/setpoint).
As soon as it was installed I was asked to secure the keyboard by pressing ctrl alt and F12 and then I had to type in a 16 digit code (given on screen) and then my keyboard started working again.
I didn't have a spare keyboard so I used the on-screen keyboard (Start - All Programs - Accessories - Ease of Access - On-Screen Keyboard).
Jan 25, 2008 | Logitech Cordless Desktop MX 3000...
Logitech Keyboard
Press Ctrl+Alt+F12.
Oct 09, 2007 | Logitech Computers & Internet
When mouse works, keyboard doesn't and vice versa...arghhh!
WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables.
Sep 18, 2007 | Logitech 967461-0403-PK Keyboard/Mouse
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
632 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
