Question about Remington Electric Pole Saw
My Remington electric chainsaw won't work at all. Plugged it in to two different three prong GFI outlets and got nothing. Last fall, I mounted the handle to the lower platform using bolts. Had to drill holes in the lower platform of saw handle because there was no other way to mount it on the pole. Are there any wires in the bottom platform that I may have drilled through?
SOURCE: what type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
  • 188 Answers
SOURCE: Our new Pole Saw, (6 mo old, used 2 times) just
Check in the handle, the wire connection to the electrical switch could have came loose or disconnected. The switch may need to be replaced. Maybe part of the cord went bad, but I would think that would be less likely, but possible if you had a electrical surge.
If the wire connection is okay, then I suggest you try to purchase a new switch part # 077525S, that may do the trick. You can by one by calling Master Distributors at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 10, 2009
  • 905 Answers
SOURCE: Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Posted on Nov 02, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
SOURCE: Remington Pole Saw
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Posted on Oct 08, 2010
I just bought a Briggs and Stratton pro series model # 30338 10, 000 watt I was trying to run my clipper masonry saw that has a 23 amp 208 -236 volt 3700 watt single phase electric motor. It ran it with #6...
There is just too much resistance in that cord. Get a 12 gage extension cord. And yes I think you burned out the generator due to severely overloading it.
Mar 02, 2017 | Electrical Supplies
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
My Whirlpool ciello only has a 2 prong plug. How do I ground the tub?
You can go to any metal part of the tub or electrical part (motor - valve - connection) and fasten a ground wire to that part using a nut and bolt or screw. I would suggest you use a screw that is already on the motor. Run the ground wire to a known good ground. The ground doesn't necessarily have to be the electrical outlet (a cold water piper, for example). There is that possibility that there is nothing metal that you will find exposed. That makes it a little tougher. If this tub came this way from the manufacturer (two prong plug), it is probably exempt from the grounding requirement. I would suspect that the manufacturer wants you to plug this device into a GFI. You can get a GFI at any store that sells electrical parts. A separate ground is NOT required for full protection when using a GFI. All consumer grade GFI (they look like a regular, rectangular outlet) come ready to accept a three prong plug and there will be a place to fasten your house wire ground to the device. As I said, the ground it not a requirement for correct and complete function of the device. If you don't have a GFI available where you are connecting the plug, change it or get a qualified electrician to change it for you. DO NOT, UNDER ANY CIRCUMSTANCES, PLUG THIS DEVICE INTO A STANDARD OUTLET . Use it only on a GFI protected circuit. The outlet you are considering may already be protected by a GFI breaker. You can only prove this by finding the breaker, turning it off and checking the outlet in question. If it is a GFI breaker, it will look different from the others - and have a test button on it. If you are unsure, replace it with a new GFI breaker. I suppose I should also say here that you should check with yout town building inspector as to the requirements before you proceed, so you will meet any local code requirements. If you live in North America, I am certain the GFI is a requirement for this installation, as the National Electrical Code requires it, (Canada and USA).
Thanks for your question here @ FixYa.com today.
Jan 06, 2011 | Whirlpool 5"x36" White Bathroom Drop-in ...
Pull trigger and saw does nothing
Assuming you are using an outside plug with a long extention core - it may be that you tripped a GFI (Ground fault receptacle or breaker) Short of that purhaps the trigger or brushes have failed? let me know how you make out.
Nov 29, 2010 | Remington Electric Chain Saw
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
Is a refrigerator usually plugged in to a GFI outlet that's connected to multiple other outlets? Is it mere poor practice or should it never be done?
A GFI outlet (Ground Fault Interrupt) is actually designed to provide extra protection from electrocution in wet areas where water can come into contact with a hot wire, and as long as the refrigerator is plugged directly into the GFI outlet and is not plugged into the GFI outlet by using any extension cord then there should not be any problem as long as the GFI outlet is not over-loaded with other appliances or large electrical demands. If the GFI outlet is tripping then either there is a faulty appliance or electrical device plugged into the GFI outlet or the GFI outlet is simply over-loaded with too much electrical demand, or the GFI breaker could be faulty. Plugging a refrigerator into a GFI outlet is not bad practice, however over-loading one is and that is what should never be done.
Oct 06, 2010 | Frigidaire Refrigerators
GFI switch outlet may have damaged Kenmore 55771 side-by-side?
Could be the GFI switch.
The washer has a 3-prong (grounded) plug, what about the other appliances that you tested?
The GFI may not have a good ground and the 3-prong appliance provided a "difference" that the GFI detected as a "fault".
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Remington Electric Pole Saw Logo
21 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
