Question about Sharp AR-M237 Digital Copier
Error Code E1-15 - can I fix this myself?
Turned on the Sharp AR-M237 to photocopy and I got an error message E1-15. Calls for service. Can I fix this myself - funds are low?? Thanks, Sheila
    Scholar:
  • 117 Answers
Most messages that state "call for service" are for instances where the unit is not running to prevent damage to the unit.
You should call an autherized or certified technician to work on the unit.
Posted on May 07, 2009
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
I bought a new photocopier, i plug it the power supply but when i tried to make some copies i failed. I asking if there are some settinng required. Name:Sharp AR-5518
to make acopy you have to load the paper on the cassette and install a new ink cartridge. and you need to place the original on ADF or on the glass and press the start botton if you are unable to make a copy please read the lcd for the or message displayed.
Dec 24, 2010 | Sharp AR-M237 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
Sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
Jun 02, 2009 | Sharp AR-M237 Copier
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
U2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
Sharp AR-M237 Digital Copier Logo
321 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
