I am trying to format my laptop, i insert Bootable CD in CDrom, machine boots, loads all the drivers, while loading windows setup. machine shuts down..please help me with this problem.
  • 3 more comments
  • shamukesh79 Apr 24, 2009
    i am using Compaq pressrio model v2624tu. i want to install windows xp
    the power cable is ok. cd is correct, as i have even installed XP on many machines..
  • Jeff Strader
    Jeff Strader May 11, 2010
    you also might clean the air ducts for the CPU, if they get clogged with dust, they will cause similar shutdowns shortly after startupas the laptop overheats.
  • Jeff Strader
    Is the power cable plugged into the wall socket while you are trying this OR are you running stickly from batteries?
  • gurpreet kapoor May 11, 2010
    what laptop ur using?name and model no. and wht os ur going to install?
    Scholar:
  • 35 Answers
There are many possibilities that would create this problem.  Can you try to install Windows on a seperate machine with the same disk? This would tell you whether the disk has been corrupted or not.  If this option is not available, I would suggest cleaning the disk well and trying again.  Again, there are many possibilities.  Your power supply may be inadequate or beginning to fail, you may have hard drive errors causing the shutdown.  The possibilities are numerous and hard to pinpoint without more information.  Check to see that your installation CD is not corrupted first.
Posted on Apr 24, 2009
  • 1 more comment
  • Tim Hallman Apr 24, 2009
    Try resetting your BIOS before your next installation attempt.  You can find instructions for doing so in your laptop manual, or by visiting the manufacturer's website.  Most likely you are experiencing a hardware conflict which could be the result of BIOS settings.  Resetting your BIOS will restore factory defualt settings and should correct your problem.  If this does not work, please try to be more specific as to when during the installation process your laptop shuts down.  thanks.
    Please keep in mind...there is a difference between flashing your BIOS and resetting it.  Flashing your BIOS can be dangerous and can permantly damage your computer.  I would recommend resetting your CMOS (BIOS) first.
    One last thought as I will not be available later.... Please remove any hardware such as wifi cards, and unplug any printers and disconnect any USB cords before attempting your next installation.
    Scholar:
  • 154 Answers
Flash the bios to get the sata native support option in ur bios & DISABLE THAT then u will be able to install xp
us nlite method software to flash bios.before it download the latest bios from compaq site.
  • gurpreet kapoor Apr 24, 2009
    check first whether u have sata native support. if it is there then no need to flash bios. jsut disable it.
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
How do i reformat my pc
Hi Good day!! Sir/Madam if you want to format your pc you will need and CD of a Operating system like WindowsXp/Vista/etc.(note you should have the product key after installing the OS)
here are the steps on reformating:
1. Open your Bios setup by Pressing del or f2 it depends on your board.
2. insert your bootable CD on your CD/DVD rom.
3. go to boot setup, set your boot priority 1st boot must be your CD/DVD rom, 2nd boot your harddisk after you set your boot priority press f10 and then save changes. it will restart your pc.
4. your computer will boot in CD and a message will appear "Press any key to boot from CD...." you should follow it. press any key!! if you boot from cd successfully you should be on windows setup it is a blue screen!! congrats!!
5. windows setup will load it's driver, when finish loading there will be a option on the bottom.
6. press f8 for terms and agreement (read carefully)
you can start formating just read the instruction.
REGARDS
JR
Oct 14, 2010 | Computers & Internet
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
My System is affected by virus.when i format the total hard drive still it can run within some days.how 2 remove this virus manually or help 2 format the drive using any bootable software...plz...
I suggest booting from a bootable cdrom disk, instead of a floppy disk, USB drive, etc. Everything except the cdrom can quite easily become infected with a virus just by plugging it into the computer. You MUST create the bootable cdrom from a KNOWN clean computer! If you try to create one from the infected system, you can almost be assured you will only create an infected cdrom!
If you don't have a way of creating a bootable cdrom, try booting your system from your Windows installation cd / dvd. Do a complete format before the install and then SHUT DOWN the computer! Do NOT just reboot and continue with the installation of the OS. Viruses are "memory resident" in that they load themselves up into RAM when the computer boots and will remain there until the machine does a complete shut down. I recommend you shutdown (i.e., turn off the computer) and restart the machine a couple of times AFTER doing the format to be assured that the virus is eradicated.
Once you are satisfied the virus no longer exists, you can go ahead with a new install of the OS. The FIRST thing to do before loading ANY of your personal files back onto the computer is to install a virus scanning software -- and make sure it is active and the virus pattern files are current. After scanning the hard drive for problems and finding none, can you go ahead with the installation / restore of your personal files.
Chances are pretty good that the reason the computer runs OK for a couple of days and then the virus reappears is that a file you have installed or copied over from your backup is infected. Each time you launch the program / file, the virus gets installed and the cycle starts again.
Jan 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
How to reformat my nc6000 using my os cd?
The NC6000 sometimes has trouble booting to anything other than the primary hard drive once a valid OS has been installed. If you need to reinstall by booting it USB or to a CD/DVD; this works for me as a last resort. (Especially USB which it officially isn't supposed to be able to do.)
Insert the bootable media. Shut the laptop down. Remove the hard drive - but leave it disconnected in the bay. Start the machine, let it detect the bootable device, then hot-plug the hard drive. There is some timing involved, but it works.
I loaded several NC6000 machines running Windows 2000 to Linux and XP this way.
Sep 27, 2009 | HP Compaq nc6000 Notebook
How to reformat my gateway 400sd4 laptop?
If you are planning to install windows after format, then u can do the formatting during the windows installation procedure. Insert the CD, boot from it. Otherwise you would need a Linux live CD
Sep 24, 2009 | Gateway 400SD4 Notebook
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Abit Guru Ai7 Hard Drive Problem
Simply....... no. Once formatted it's reinstall time.
You can load you're windows cd into the cdrom drive & try to get windows to load. If you do get the cdrom to load - (Press any key to load from cd...... ) & press any key. Once in windows setup ( DO NOT format the drive) but do reinstall windows, if windows see's another windows on your drive, great install over it. If windows does re-install it's self you should have enough time to install burner software & back up your personal data to CD or DVD before your partition looses it's cookies & shuts you down.
You can also leave it alone & install another drive & setup windows complete & slave it back into you're system for IDE.
SATA's are all master drives. Than copy your data back to you're new drive. In these cases I always suggest the user go to the web site of the hard drive & download the Mfg's bootable software tool's/setup utilities. Windows is not perfact at formatting.
Luck!
Mike
Apr 08, 2008 | Abit A17 Guru Motherboard
Something isn't working right..
another way around this is to insert a boot-able floppy disc, then select "Boot with CDROM driver" and then find the new drive letter associated and then insert CDROM...and then run setup.exe
Nov 03, 2007 | KDS Valiant 6370iPT Notebook
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
