Question about Rangemaster Kitchen Hood
How to locate and replace fuse for lights on Rangemaster RMP 17000?
My rangemaster cooker hoos has just stopped working.. no fan working and no light coming on ??
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 20, 2010 | Rangemaster Kitchen Hood
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
Dec 17, 2009 | Rangemaster Classic 110 Kitchen Range
Rangemaster stove hood blower nor light works anymore
rangemaster have a tech help desk. you can find the number on the internet.
Feb 19, 2009 | Rangemaster Kitchen Hood
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Faulty plate warmer on rangemaster 110 dual fuel
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Jan 20, 2008 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Kitchen Hood Logo
59 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
