Question about Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera
Reset camera? - Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera
I need to reset the password it's been a while and i forgot it.Can you help me
I don't know what brand your IP camera system is. According to my experience of using Reolink's IP camera system:
1.If you want to reset the IP camera's password, normally, the camera has a reset button. Take my camera as an example:
need-reset-password-s-while-forgot-kn01uzg0poojzx3dnu2rqo55-2-0.png You press the reset button, then you can reset your IP camera's password.
2.If you want to reset your NVR/DVR's password, as far as I'm concerned, you can try pressing the reset key of NVR/DVR's mainboard for 10 seconds. Remember that don't open any menus. If everything goes fine, you will hear a sound of buzzer. Then you can reset your password of your NVR/DVR. I hope it could help you solve your problem.
If you have other IP camera problems, you can visit Reolink's forum, I got a lot of help there.
IP Camera Reolink Forum
Apr 22, 2016 | Home Security
How can i reset factory setting on my sony dsc55 camera
Reset button on the camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Initialize or Reset option(s) in the camera menus
  • The menu layout is different between cameras so check the operating instructions.
  • In general, there will be a Reset or Initialize section within the menus of the camera.
  • Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Jan 06, 2015 | Sony Cyber-shot DSC-W55 Digital Camera
How to reset sony dsc-w90 to factory setting
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
Follow the appropriate procedure below for your camera. Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button:
Performing a manual power reset:
Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Hope this helps.
Oct 07, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
I need to' reset The camera . How can i do ? Thanks
  • Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Aug 10, 2010 | Sony Cyber-shot DSC-W300 Digital Camera
Hi i have sony h7 and wan to reset to factory
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Jun 26, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
My screen shows lines and when I take a picture
Please reset the Camera and check if that helps.
To reset the Camera, just press the RESET button using a sharp-pointed object. The Reset button is located inside the jack cover. Please make sure that the Camera is turned ON while pressing the RESET button.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON and check if that helps.
Thank You!
Apr 09, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Where is the reset on hp r707 digital camera
There is no reset button on this camera. For reseting it follow these steps (from the MANUAL, page 122):
1 In the Setup Menu , select Reset Settings....
2 In the Reset All Settings? sub-menu, highlight one of these
two choices:
? Cancel ? Exits the menu without resetting any of the
settings.
? Yes ? Resets all camera settings to their default value in
the Capture Menu and Setup Menu (except Date & Time,
Language, TV Configuration, and USB Configuration).
3 Press Menu/OK to reset settings and return to the Setup Menu.
Apr 07, 2010 | HP Photosmart R707 Digital Camera
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Aug 27, 2009 | Sony Cameras
Cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  4. if you dont have a reset button try the manul reset below
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Aug 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
ALL RESET
The ALL RESET function works two ways. When it is set to ON it restores the camera to the default settings once the camera is powered off. You can still put in custom settings, but they will be reset when you turn the camera off. When it is set to OFF the camera remembers the settings you have entered. For example, if you want the camera to always start up in the 3:2 aspect ratio you would turn ALL RESET to OFF and then select the 3:2 quality setting. The 3:2 setup will be there every time you start the camera up until you set ALL RESET to ON. When ALL RESET is set to OFF the camera will accumulate all of your setting changes, so it is recommended to reset the camera occasionally.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Open Questions:
See all Olympus ? Tough 3000 / Stylus Tough 3000 Digital Questions
Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera Logo
24 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
